How to post configuration snippets
The discourse forum software supports code snippets. To keep everything nice and readable, please “code” your configuration snippets.
How not to add configuration snippets
Don’t do this:
hostname PE1
interface GigabitEthernet0/0
ip address 10.255.2.113 255.255.0.0
shutdown
duplex auto
speed auto
media-type rj45
It’s difficult to see the difference between regular text and configuration snippets. It’s messy!
Use the code button
Select your configuration snippet and use the code button. See screen shot below:
You will know when it works, as the text you selected will become indented. Over in the preview pane, you will see the text coded with a colored background.
Your configuration snippet now looks like this:
hostname PE1
shutdown
duplex auto
speed auto
media-type rj45
Much, much cleaner!
- Instead of the code button, you can also use HTML:
<pre><code>my configuration snippet</code></pre>for configuration snippets.- or
<code>hostname R1</code>for commands.
Add only the relevant configuration snippet
Don’t post the entire configuration. For example, if you only have a question about MP-BGP on your router then don’t paste the entire configuration:
Building configuration...
Current configuration : 3769 bytes
! Last configuration change at 14:41:41 UTC Wed Aug 8 2018
version 15.6
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip vrf CUSTOMER
rd 1:1
route-target export 1:1
route-target import 1:1
ip cef
no ipv6 cef
redundancy
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip vrf forwarding CUSTOMER
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
duplex auto
speed auto
media-type rj45
router ospf 2 vrf CUSTOMER
redistribute bgp 234 subnets
router ospf 1
mpls ldp autoconfig
router bgp 234
bgp log-neighbor-changes
neighbor 4.4.4.4 remote-as 234
address-family ipv4
no neighbor 4.4.4.4 activate
exit-address-family
address-family vpnv4
neighbor 4.4.4.4 send-community extended
exit-address-family
address-family ipv4 vrf CUSTOMER
redistribute ospf 2
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ipv6 ioam timestamp
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
login
transport input none
no scheduler allocate
Besides the junk and empty lines, we don’t need the login banners and SSH configuration.
Only paste the relevant configuration snippet that we need to answer your question:
router bgp 234
address-family ipv4
exit-address-family
exit-address-family
redistribute ospf 2
exit-address-family
Nice, clean, and easy on the eyes.
Don’t add sensitive information
Our forum is read-only to the public so remove any sensitive information like IP addresses or usernames in your configuration snippets!
