How to Upgrade Cisco IOS Bootstrap
why upgrade a bootstrap in the first place or what scenarios in which we need to upgrade the boostrap? Thanks Rene
Hi Don,
It’s not a common thing to do. It is possible that you need to do on an upgrade when you want to install a new IOS version. I also vaguely recall that the 1841 routers can boot from USB but only with a certain (newer) version of the bootstrap.
