I have a network with no routers but 25 layer 3 IE3000 switches with no Internet access. I’m unable to ping between VLANs and get “Destination unreachable” most times. But able to ping between devices on VLAN 1 on all parts of the network. I think I’m missing an ip route statement but not sure what to point it to if there is no router. I am running Layer 3 on all switches via ip routing statement.
- I can ping from a host to the default GW of the VLAN that they belong to.
- I know the trunks are working because I can ping VLAN 1 from any part of the network.
- Sho IP route only shows those VLANs with hosts connected to them - which is usually normal.
- Port-Channel 1 will be applied to port 0/7 and 0/8 when this problem is remedied. Port-channels will not be applied on all switches.
- VLAN 111 and VLAN 112 are supposed to be L3 trunk interfaces between the switches.
Thanks for your help …
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch2
ip routing
spanning-tree mode rapid-pvst
interface Port-channel 1
description *** SW01-SW02 LAG ***
switchport trunk native vlan 99
switchport trunk allowed vlan 101-103,111-112
interface FastEthernet0/1
switchport access vlan 101
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 102
interface FastEthernet0/3
switchport access vlan 103
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport trunk allowed vlan 100-101,111-112
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
description *** L3 LINK TO SW02-Gi1/1 ***
interface GigabitEthernet0/2
interface Vlan1
ip address 10.1.1.26 255.255.255.0
interface Vlan101
ip address 10.30.1.2 255.255.255.240
interface Vlan102
ip address 10.30.2.2 255.255.255.240
interface Vlan103
ip address 10.30.3.2 255.255.255.240
interface Vlan112
ip address 10.30.0.5 255.255.255.252
ip default-gateway 10.1.1.1
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
