Hi Guys,
Is it correct to say that that no IGP uses TCP/UDP at the transport layer? This is because they all require a reliable transmission that supports multicast?
Gareth.
Hi Guys,
Gareth.
Hello Gareth
OSPF and EIGRP run on top of IP on the Network layer. They have their own headers that are added to the IP headers. These are displayed as an additional level of information within Wireshark. An example of this for OSPF is found below:
Sometimes, EIGRP is stated that it uses RTP. But this statement can be misleading. EIGRP uses Reliable Transport Protocol and not Real-Time Transport Protocol. The latter is a Transport layer protocol used for voice and video applications. The former is an EIGRP specific framework that describes the way in which EIGRP messages are exchanged. Itâs not on the Transport layer, but on a layer on top of the Network layer, much like OSPF is.
RIP on the other hand does use a transport layer mechanism, specifically using UDP port 520. You can see this in the following Wireshark output:
Finally, IS-IS doesnât use the Transport layer, but interestingly enough, it doesnât use IP either. It is its own communication protocol that is running over IEEE802.3 Ethernet. A Wireshark example of IS-IS in action can be seen below:
So really, each routing protocol has its own methodology of communicating, but with the exception of RIP, the most common IGPs do indeed function at up to Layer 3.
For completeness, let me just mention that BGP uses a Transport layer mechanism, specifically on TCP port 179.
Thanks Laz.
Looking at the packet captures you supplied, is it significant that IS-IS is built upon âIEEE 802.3 Ethernetâ whilst OSPF and RIP use âEthernet IIâ?
Gareth.
Hello Gareth
Yes, actually, that is very significant. IS-IS is a protocol that has been developed to strictly adhere to the OSI model and not the TCP/IP model. IEEE 802.3 adheres to the OSI model whereas Ethernet II, strictly speaking, does not. Remember that the OSI model separates the Data Link Layer into two sublayers, the Media Access Control (MAC) and the Logical Link Control (LLC). IEEE 802.3 adheres to this, providing both a MAC and LLC sublayer component, which can be seen in the Wireshark output. Ethernet II does not, and is thus not compatible with IS-IS.
R2 and R4 form L2 adjacency but why do they install 192.168.24.0 in their L1 database. Arenât they supposed to maintain it in their L2 database only?
Hello Raj
It is true that R4 and R2 are L2 neighbors, but the 192.168.24.0/24 network must also be advertised to the other L1 routers such as R3 and R4 so they can know how to route to it, and must thus be included in the L1 LSP.
Hii Rene,
i am working in ISP . ISIS & OSPF & BGP troubleshooting is my basic day to day Activites.
planning to shift Job. Kindly provide your suggestions whether to learn Phyton or Datacentre firewalls or anyâŚ
Hello Chandrasekhar
Your job sounds like a great opportunity to learn a lot. Troubleshooting for an ISP and working with these protocols means that you get a lot of hands-on experience. If youâre looking to move into another area and enrich your skill set, there are a lot of things that you can do. Learning Python, moving into more in-depth data center issues, or focusing on security and firewalls are all good choices. All three are very âin demandâ and you will find jobs easily with these specializations.
My suggestion would be to choose what you like best. It is so important to love what you do, because you will be spending more time in your job than with your family! So since all of these areas are in high demand, choose the thing that will give you the most pleasure. That way, you will like your job, and automatically you will be better at it.
Hi all,
Do you know how to test this feature by show result âŚ
Hello Quy
Applying prioritization for prefixes within ISIS imply involves the tagging of your choice of prefixes, and then configuring the device to give priority to those tagged prefixes, so they are updated first in the RIB. More on this process can be found at this Cisco Documentation.
Now in order to see the tags that have been assigned, you can use the show isis rib command. This will output the prefix and include the assigned tag. By default, such tags are set to 0. You can find out more about this command at the following link:
Great ! Your suggestion is very userful. I can see the result.
I see a lot of clns command like
sh clns neig
sh clns nei detail
sh clns interface
I didnât find these commands in ISIS topic. Can you please explain their command outputs along-with topology?
Hello Bhupesh
CLNS stands for Connectionless-mode Network Service. This is an OSI Network layer service and is similar to the services provided by a combination of IP and UDP. IS-IS is compatible with this service and can be used to route CLNS traffic. However, CLNS is not as popular as TCP/IP, and has since been on the decline. Even so, it is supported by Cisco equipment, as you have seen in the commands you mentioned.
Because it is not part of the Cisco certification topics, it has not been included in the lessons.
What is the difference between LSP and CSNP .When I did packet capture there are NLRI info in the both packet so I am bit confuse to understand the difference .
Thanks in advance
Hello BGP
ISIS uses various types of Protocol Data Unit (PDU) types in order to exchange routing information with peers. These include:
Link State PDUs (LSPs) - which advertise its neighbors and the destinations that are directly connected to the router itself.
Sequence Number PDUs (SNPs) - which contain a summary description of one or more LSPs. There are two types of SNPs, one of which is:
You can find out more detailed information about these and other PDUs that are used by ISIS at the following CIsco documentation:
This is the config that i am trying to understand . i tried to find on lines highlighted in bold. But, not finding much details on these. Please add these subtopics also.
Can you please help me to understand why do we use these commands ?
router isis IGN
is-type level-2-only
net xx.xxbb.00xx.000x.00xx.00
log adjacency changes
lsp-gen-interval maximum-wait 5000 initial-wait 1 secondary-wait 50
lsp-refresh-interval 64000
max-lsp-lifetime 65500
purge-transmit strict
address-family ipv4 unicast
metric-style wide
mpls traffic-eng level-2-only
mpls traffic-eng router-id Loopback99
mpls traffic-eng multicast-intact
spf-interval maximum-wait 1000 initial-wait 150 secondary-wait 150
distance 115 0.0.0.0/0 GEN-ACL
distance 255
segment-routing mpls
Bhupesh
Hello Bhupesh
lsp-gen-interval - This command is used to throttle, or regulate the frequency with which LSPs are generatedlsp-refresh-interval- The refresh interval determines the rate at which Cisco IOS software periodically transmits in LSPs the route topology information that it originates. This is done to keep the database information from becoming too old. Reducing the refresh interval reduces the amount of time that undetected link-state database corruption can persist at the cost of increased link utilization.max-lsp-lifetime - Sets the maximum time for which LSPs persist without being refreshed. Values are in hoursmetric-style wide - used to configure an IS-IS router to use the new-style type length value objects (TLVs)mpls traffic-eng level-2-only - To configure a router running IS-IS so that it floods MPLS-TE link information into IS-IS level 2.mpls traffic-eng multicast-intact - Allows PIM and MPLS to work together.spf-interval - used to throttle or regulate SPF (shortest path first) calculations for IS-IS convergencesegment-routing - enables segment routing for IPv4 addresses within the MPLS data plane.These are commands that deal with the use of IS-IS within an environment where MPLS is used. For more information, take a look at these Cisco documents:
If youâre interested in seeing a lesson on the site that has to do with one or more of these types of topics, feel free to make a suggestion at the Member Ideas page below. You may find that others have made similar suggestions to yours, and you can add your voice to theirs.
Thanks Laz for the perfect response.I will take a look. Thanks for the document links also.
Thanking you,
Bhupesh Saini
Why IS-IS mostly used in SP environment?? OSPF in enterprise network. Please mention some points
Hello Muhammad
The fast answer is that IS-IS is more suited for larger networks. Indeed, it has been called the âde facto standardâ for large service provider backbone networks. IS-IS outperforms OSPF as networks get larger. Conversely, OSPF was designed to work well in smaller networks and it works better than IS-IS.
There are several reasons for this, and it all has to do with the design of each routing protocol.
Both are link-state protocols and both use the Dijkstra algorithm. However:
Now part of the fact that ISPs are using IS-IS also has to do with history. In the 1990s, ISPs generally chose IS-IS over OSPF due to the fact that Ciscoâs implementation of IS-IS was much more stable at the time. It was kind of a no-brainer that you would choose IS-IS. Since then, OSPF has improved its stability for large networks, but the use of IS-IS still stuck. In addition, IS-IS seems to be more âtunableâ in certain aspects that make it preferable by larger networks. And since the 1990s, IS-IS has been further developed to support the needs of larger networks.
So all of that together has caused ISPs to lean more towards IS-IS than OSPF for large networks.
