Its really cool amazing way of explaining ospf you made it to soft easy to understand I really wish
You all success in your carrier.
Mustafa
I’m glad you like it!
you know the actual way to teach. your lessons are very helpful than any other blogs and i love this site…Thank u very much.
Go ahead…May god bless u.
Khalidh
Thank you for your kind words Khalidh!
Thank u very much for you lessons!!! I planned pass CCNA in May 2014. Thank you for you lessons!!!
hello mr Rene
i would like to thank you for making me to understand ospf concepts you are the best tutor and this is the best site for learning ccna
thank you soo much
have a great day
Its really very much helpful for freshers.
Very good Information for quick learning
that was so useful thnx
The one exclusive sign of thorough knowledge is the power of teaching.Rene your teaching styles is quite explecite and down to earth.You videos are so wonderful and easy to understand.
I have a question regarding the reference bandwidth.If i am not making a mistake,you made mention about some older version of the cisco ios using a reference bandwidth of 100Mbit and the Newer versions 1000 Mbit.I was curios to know how the reference bandwidth can be verified on a cisco ios.
Thanks in advance
Hi Emmanuel,
Thanks for your kind words
Glad to hear you like it!
You can find the reference bandwidth with the show ip ospf command, for example:
R2#show ip ospf | include Reference
Reference bandwidth unit is 100 mbps
Thanks rene.your assistance was well appreciation.Keep on with the good work.
Kind Regards
Emmanuel
Thanks rene.your assistance was well appreciated.Keep on with the good work.
Kind Regards
Emmanuel
Read more: https://networklessons.com/ospf/introduction-to-ospf/#ixzz3JcFqTtYF
Excellent way of teaching… From today, you are my inspiration of teaching cisco topics to others ![]()
HI Rene,
nice explanation ..![]()
i have a question.
if we have 16 equal cost paths to a specific destination , all these 16 paths will be placed in routing table?
and one more thing is that, cost =100Mbps/link bandwidth.
if the link is gigabit Ethernet, then the cost will be in fractions right, so how will it managed?
“To make paths equal cost, change the “cost” of a link” can u give me an example of the same.
praveen
Hi Praveen,
Yes that’s right, if you have 16 equal cost paths then all of them will be in the routing table. By default OSPF will only use 4 equal cost paths so you’ll have to change this if you want to use more than 4.
About the cost, that’s a good question…if the reference bandwidth is 100Mbit then a Gigabit link would have a cost of 0.1.
Cisco IOS however doesn’t use a cost lower than 1 so a FastEthernet and Gigabit link both will have a cost of 1. If you use Gigabit links, it’s better to change the “reference bandwidth” to Gigabit…this means Gigabit will have a cost of 1 and FastEthernet a cost of 10.
Hi Rene thanks very much for my last response on the Networking designing recommendation. I will like to quickly ask if you have taken two test of the old ccnp exams in my case 642-802 and 642-813, and i dont take the 642-832 before it expires, would i loss the first two exams, or can i take the new tshoot to make me a full ccnp thank you.
If your 642-802 and 642-813 certifications are valid then you can do the new TSHOOT V2 exam and you will be fully CCNP, that’s no problem at all.
Very Helpful, Thanks Rene.
