Why should one waste time studying VTP when it’s not include in 200-301?
Hello Thomson
I understand your concern about this. However, on all of Cisco’s exam pages, it says the following:
The following topics are general guidelines for the content likely to be included on the exam. However, other related topics may also appear on any specific delivery of the exam.
VTP is definitely considered a related topic to many switching topics, so it’s always a good idea to have included it in your studying. Beyond any certifications, learning about VTP is helpful since you may need to implement it at some point as well.
Hello Rene/Lazaros,
Thank you both for the great and detailed explanations.
Is VTP turned on by default? How do you disable it if you don’t want it in your network?
Is it the same for all models?
Chris
Hello Chris
Initially, a switch will have the following default parameters for VTP:
- VTP operating mode: Server
- VTP Domain Name: Null
In such a case, VTP is active, but switches will not actively create any VTP associations with any other switches simply because the domain has not been configured. When all switches have a domain of NULL, it is as if VTP is not functioning.
However, this can still be a dangerous situation, because if a rogue switch is added which has a VTP domain configured, it will start to send VTP messages, and any switch on the network that still has a NULL domain, will automatically adopt that domain as well.
You can’t disable VTP as a feature, but you can ensure that a switch never participates in any VTP domain that may appear on the network by simply changing the VTP mode to transparent like so:
Switch(config)#vtp mode transparent
This ensures that any VTP messages received will be ignored.
Yes it was very helpful, thank you!
I’m configuring VTP pruning, as this topology
R5 and R6 connect to access port of vlan 100 on sw2 and sw4. I enable vtp pruning on sw1.
When I ping from R5 to an IP address, ex 10.1.2.100 to generate ARP packets, sw1 still forwards ARP traffic to sw3 , although sw3 does not have any accessport in vlan 100.
Pls help to explain. Tks you.
Hello Hai
Indeed, based on your explanation, ARP packets sent by R5 should not reach SW3 due to VTP pruning. However, from the image you have shared, it looks like you’re using GNS3. Others have found similar incorrect behavior when using GNS3, and this may be a similar result. Take a look at this Cisco learning network post:
Hi, Rene.
- Would this (reset the revision number) be the recommended way to avoid the problem you mention early in the letter (experiment on a switch in the lab, delete your experiments, reattach switch to network)? Or is there another/better way to avoid that?
Resetting the revision number is probably the best way to ensure that adding a switch to your topology will not change the VTP configuration of all the switches.
There are a couple of ways to reset the revision number in VTP:
- change the VTP mode to transparent, and then back to server or client mode
- change the domain name and then change it back
In any case, it’s always best practice to make a switch VTP transparent before connecting it to the network. Once connected, you can then change it back to whatever you need, ensuring that the revision number is indeed smaller than the rest of the switches.
Great lessons. And I have little suggstion to it. I tried to configure VTP manually, but it didn’t work, untill I found on VTP Cisco page, that VTP requires trunk between switches. I think it’s little confusing to learn VTP before Trunk. since VTP doesn’t work without trunk. So suggestions is to put Trunk Lesson before VTP and mention that VTP requires active trunk, so that students can practise VTP without jumpnig between lessons or trying to understand why VTP doesn’t work. I don’t know, if someone had this problems also, but for me it wasn’t clear. (Yeah VTP stays for VLAN “TRUNKING” Protocol, but again as a newbie I didn’t get it)
Hello Shahlar
Thanks so much for this feedback. The VTP lesson is part of various courses and may appear elsewhere in the order of lessons as they appear for each course. In the Switching course, VTP appears after trunking:
In other courses, it may indeed appear before trunking. In all cases, however, it is indeed helpful to indicate in the lesson itself that a trunk link is necessary between switches in order for VTP to operate.
I will let Rene know to take a look and make any necessary modifications to the lesson.
Thanks again!
Hi Laz
Okay, got it. Thank you for your answer. Glad to be helpful!
VTP advertisements are not mentioned
VLANs creates different broadcast domains, how broadcast traffic will impact another link having different VLAN?
Hello jijith
If you want to find out more about VTP advertisements, take a look at this NetworkLessons Note on the subject. Rene does mention advertisements in the lesson, but not to any extent. Hopefully, this will cover what you need.
Hello Amit
When a broadcast is sent on a particular VLAN, let’s say VLAN 10, that broadcast will be sent out of all access ports that are on VLAN 10, and out of all trunk ports that include VLAN 10. If we were to draw a line around that broadcast domain on the diagram within the lesson, we would get something like this:
As you can see, we would have broadcasts on VLAN 10, sent out of the main switch to the middle switch (highlighted in yellow). This traffic is useless since no hosts exist on VLAN 10 on the middle switch.
Now how would this impact another link having a different VLAN? If there was another access or trunk link that doesn’t include VLAN 10, then it would be unaffected, since broadcasts would not exist on any other VLAN except 10.
Hello, my question is about revision numbers on VTP Transparents. If the VTP Transparent receives an update, but does not synchronize and only forwards the information, does the VTP Transparent’s revision number change or stay the same?
Hello Mario
That’s a good question. I went into the lab and checked this out. I have found that on transparent switches, the revision number always remains zero. Even though I added several VLANs to this switch, you can see that this is so:
SW1#show vtp statu
*Nov 9 06:38:55.759: %SYS-5-CONFIG_I: Configured from console by consoles
VTP Version capable : 1 to 3
VTP version running : 2
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP Traps Generation : Disabled
Device ID : 5254.0006.8000
Configuration last modified by 0.0.0.0 at 11-9-22 06:37:31
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 1005
Number of existing VLANs : 14
Configuration Revision : 0
MD5 digest : 0xD8 0x87 0x4A 0xF5 0x0D 0x70 0x90 0x91
0x65 0x54 0x4B 0x9F 0x2A 0xC2 0x95 0xCC
SW1#
This means that even local changes made do not change the revision number of the transparent switch, nor do any VTP messages that a transparent switch may receive and relay to other switches. This makes sense, because a revision number has no meaning for a transparent switch from the moment that its VLAN configuration remains completely independent of any other switch on the network.
Hi there,
At the begining of this topic you need to write that first of all moves ports to trunk mode. VTP couldn’t work without it.
Hello Yatsenko
When a switch has VTP enabled, and it has no domain configured, then the very first VTP message it receives will cause it to assign the domain name in that message to itself. Once this is done, the VTP domain can only be changed manually. This is simply how VTP operates.
If subsequent VTP messages have a different VTP domain, they will be ignored, because they belong to a different domain.
As soon as a switch joins a VTP domain, it will automatically adopt the most recent VLAN configuration sent out by the VTP server. That’s why SW2 and SW3, as soon as they were configured with the VTP domain, adopted all of the changes to the VLANs that had been done to SW1.
