Hi Network Lessons,
I have these router logs below if you could identify what is causing the following notifications.
*Aug 23 16:10:01.038: %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 90% exceeds the setting threshold.
*Aug 23 16:10:26.037: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 48% recovered.
*Aug 23 16:17:56.038: %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 92% exceeds the setting threshold.
*Aug 23 16:18:26.037: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 25% recovered.
*Aug 23 16:18:56.037: %IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 88% exceeds the setting threshold.
*Aug 23 16:19:26.037: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 27% recovered.
show version
Cisco IOS XE Software, Version 16.12.05
Cisco IOS Software [Gibraltar], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.12.5, RELEASE SOFTWARE (fc3)
System image file is "bootflash:c1100-universalk9_ias.16.12.05.SPA.bin"
cisco C1111-4P (1RU) processor with 1401540K/6147K bytes of memory.
Processor board ID FGL2404LKNM
1 Virtual Ethernet interface
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2863103K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
show processes cpu history
922222245677658879873222222223223322222232222222322222322333333333333333
100
90
80
70
60
50
40
30
20
10 * ****
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
* = maximum CPU% # = average CPU%
