Ip nat inside destination
many thanks for the good explantions in your lessons, I found it multiple times very helpful!
I’m looking for a good and detailed description for this feature, but I couldn’t found anything here in networklessons. Overlook I something? Or better where can I find it here?
Thanks in advance!
Reinhard
Hello Reinhard
The command you are referring to is the one shown in this particular Cisco command reference:
I have created a NetworkLessons note on the topic with some additional information and links. I hope you find useful.
Hi Lazarus,
many thanks for the explanation and the links. This helps a lot.
Best regards
Reinhard
