IP NAT inside source vs IP NAT outside source
Hello Helen
Yes, this is something that can be achieved, as was done in the lesson. There is no restriction to keep the translated address in the same subnet. In the case of the lesson, this had to be done because the device whose address is being translated is directly connected to the outside interface of R1. On the Internet, for example, you could translate to any other public IP address.
Another useful application would be to translate the IP address of say, an external web server, to an internal local address. This is what I mean:
Imagine you are H1 and you want to access the web server. But for some reason, H1 is not allowed to access any external hosts, say for security pruposes. You can create the following:
ip nat outside source static 204.123.123.55 192.168.1.55
This allows H1 to communicate with 192.168.1.55 on its own subnet. R1 will receive such packets, and translate and send them over the Internet to the web server. When they come back, they will be translated again, making H1 think that it is communicating with a device on its own subnet.
Just another use of the specific feature.
I have an ASAv on AWS. I need to be able to nat an internal ip to an external ip. In other words, from the local lan I would ping say 192.168.1.12 which would be translated to 8.8.8.8 and then sent to the internet. Obviously to reply from pining the 192.168.1.12 address would come from 8.8.8.8
Hello Kevin
It looks like you will be needing the ip nat outside source command. Take a look at the following lesson which describes this feature in detail.
If you have further questions concerning your implementation, let us know!
Hi everyone, I’m still a bit confused with what goes with what.
there are two configuration mode commands:
ip nat insider source static
and there are two interface commands:
ip nat insider
ip nat outside
how do we mix and match between these commands? and whats the use case for each scenario?
Hello Odai
The following commands are used to designate which interface is INSIDE and which is OUTSIDE as far as the NAT configuration is concerned. These are just used to define the inside and outside interfaces:
ip nat inside
ip nat outside
The ip nat inside source static command configures your most commonly applied NAT translations, where inside source addresses, say from your PC, are translated to outside (publicly routable) source addresses when communicating on the Internet. Responses from the internet (in the opposite direction) are then translated so that the outside destination address is translated to an inside destination address.
Now IP nat outside source static will do the opposite. That is, for any communication originating on the Internet, when the packet reaches the NAT router, the outside source address (of the initiator) is translated to an inside source address. Responses are translated accordingly, where the inside destination address is translated to the outside destination address.
This can be useful when you have an internal service on your network with an IP address of 10.1.1.1 for example, and it is configured to accept only communication from source IP addresses on the same subnet. By employing ip nat outside source static, a device on the outside can appear to have a source IP address on the same subnet, once NATt’ed.
Thanks for the explanation Laz. What differences in behaviour would I expect to see if using .254 (the IP configured on the interface) instead of .200? I’ve done that and have noticed some differences in the ping results as well as debug ip nat output.
My topology is R1—NAT----ISP with the same IPs as per this lesson.
R1-NAT:192.168.1.1/24
NAT-R1: 192.168.1.254/24
NAT-ISP: 192.168.2.254/24
ISP-NAT: 192.168.2.2/24
  1. When pinging from R1 to 192.168.2.254, the ping is successful but I don’t see anything in debug ip nat. Should this not be picked up in the inside to outside translation? When using .200 instead of .254 I see both outside-inside and inside-outside in the debug.
  2. When pinging from R1 to 192.168.2.2 the ping is successful but I only see the NAT debug from the reply from ISP. See below. Should I not see a line in the debug for inside to outside translation as well. This behaviour is the same no matter if I’m using .254 or .200. Why isn’t the outgoing packet from R1 being natted?
*Oct 25 15:19:09.728: NAT: s=192.168.2.2->192.168.2.254, d=192.168.1.1 [146]
  1. When pinging from R2 to 192.168.1.1, the ping is unsuccessful. I see only the outside to inside part of the NAT translation. On R1 it looks like it’s replying but there is no translation back from inside to outside. When using .200 instead of .254 I see both the outside-inside and inside-outside debug activity and don’t have any issues pinging.
NAT#
*Oct 25 15:43:49.918: NAT: s=192.168.2.2->192.168.2.254, d=192.168.1.1 [128]
R1#
*Oct 25 15:43:49.918: IP: s=192.168.2.254 (Ethernet0/0), d=192.168.1.1, len 100, input feature, MCI Check(108), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Oct 25 15:43:49.918: IP: s=192.168.2.254 (Ethernet0/0), d=192.168.1.1, len 100, rcvd 1
*Oct 25 15:43:49.918: IP: tableid=0, s=192.168.1.1 (local), d=192.168.2.254 (Ethernet0/0), routed via RIB
*Oct 25 15:43:49.918: IP: s=192.168.1.1 (local), d=192.168.2.254 (Ethernet0/0), len 100, sending
*Oct 25 15:43:49.919: IP: s=192.168.1.1 (local), d=192.168.2.254 (Ethernet0/0), len 100, sending full packet
NAT#show run | sec nat
 ip nat outside
 ip nat inside
ip nat outside source static 192.168.2.2 192.168.2.254
Hello Bhawandeep
This is normal behavior. When you ping the 192.168.2.254 address, the outside interface will receive this packet, and must decide what to do with it, based on the destination IP address, in the following manner:
  • It looks at the destination IP address. If it is its own, then the interface knows that it itself is the destination of the packet. It will not translate it using NAT, but will decapsulate it and process it. In your case, it will respond to the ping using itself as the source IP address, and it will use the routing table to find out the next hop to respond to the ping.
  • If the destination IP is not that of the interface, only then will it go to the next step of checking NAT translations. In the case of using .200, this is what happens. So in this case, you will see the NAT translations in the debug.
See NAT order of operations for more details.
Hmm, that’s interesting. When using .200 you should see both translations, as shown in the lesson. However, when using .254, you will only see one translation. This once again is due to the NAT order of operations. Routing will take place before NAT translation. Since .254 is in the routing table as a directly connected route, no NATting will take place, but only routing. Can you check again the behavior when using .200 in your lab?
This once again has to do with NAT order of operations, and how they are different for inside-to-outside translations, and outside-to-inside translations. Take a look at the NAT order of operations document link above and see if you can figure this one out. If you have further questions, feel free to let us know!
Thanks so much Laz. I will complete the lessons here, read the order of operations doc and then come back to you.
Hi Renee,
Great tutorial and everything, really well and clear.
Just to avoid confusion/have these examples closer to real-world scenarios, can you input public IP’s instead of private IP’s where we would expect/see these?
Samad Khan
Hello Samad
An example of how ip nat outside source could be useful is the following:
Imagine the following scenario:
You have a network with strict security policies. The hosts on the 192.168.1.0/24 network are not allowed to communicate with the Internet due to the highly sensitive nature of the information they manage. However, you want H1 to have access to a single web server S1 on the Internet without violating the policy of “internal only” communication.
Using the ip nat outside source feature, you can assign an internal network address, such as 192.138.1.100 to that outside web server, allowing internal devices to reach it as if it was on the same subnet. Thus, from the point of view of H1 for example, the web server is on the same subnet, so no security policies have been violated.
The truth is that these scenarios are rare, but we do see them often enough so that the command can be useful. Also note that you can use public addresses in such a scenario, as you have seen from the above example.
Hello Laz ,
Quick help while configure ip nat outside source static why we placed 192.168.2.200 ?
Shivam Chaudhary
Hello Shivam
The answer is in the next post here:
Take a look and if you have further questions, let us know!
that one is understood but i m confused in ip nat outside source static , how it come in picture i m unable to retrieve the things properly means how the destination nat work here
One more think we can choose any public ip not from the subnet range that we placed here ?
Hello Shivam
Take a look at this post I responded to earlier:
You can actually choose any IP address you like, as long as the rest of the internet (your ISP primarily) knows how to route to that IP address. It doesn’t actually have to be on the same subnet as the real outside interface IP address. Take a look at this NetworkLessons note for more information.
I’m getting a little confused about using the same IP address (192.168.2.200) in both NAT statements. Wouldn’t that create a conflict or ambiguity in the translation table?
Could you please explain the logic behind this configuration?
R1(config)#ip nat inside source static 192.168.1.1 192.168.2.200
R1(config)#ip nat outside source static 192.168.2.2 192.168.2.200
Hello Hind
I understand how this can get confusing. Let me try to clarify.
Each of these NAT statements operates on completely different dimensions of the NAT translation, so they coexist peacefully in the translation table.
When a packet arrives on the outside interface, the router applies the ip nat outside source rule. The source of the IP packet is translated from 192.168.2.2 to 192.168.2.200. So this translates H2’s address (the source of the packet).
When a packet arrives on the inside interface, the router applies the ip nat inside source rule. The source of the IP packet is translated from 192.168.1.1 to 192.168.2.200. So this translates H1’s address (the source of the packet).
The router never confuses them because it knows the ingress interface direction before looking up the translation table. When a packet arrives on the outside interface, the outside source rule applies. When it arrives on the inside interface, the inside source rule applies.
It all has to do with the direction the packet is taking, keeping in mind that the source address is being translated. So both can coexist, they just translate different sources each time. The IOS NAT engine tracks the type and direction of each entry separately, eliminating conflicts and ambiguity.
Now this is indeed an unusual configuration, using the same address in this way. Typically, you wouldn’t do this, but it does work, and the purpose of the lab is to show this. But you’re right. Although it is not wrong, it’s not commonly done.
