Can anyone please explain me the difference between “ip route” and “ip default-network” commands? Can you also provide example or scenario where " ip default-network" command is used?
Hello Sumant
The ip route
command is used to install a static route into the routing table. This static route can be to a specific destination such as the following:
ip route 192.168.5.0 255.255.255.0
or it can also be used to install the default route like so:
ip route 0.0.0.0 0.0.0.0
The ip default-network
command is another way of indicating a default route. By issuing the command ip default-network 198.15.15.0
for example, what you are telling the router is “if you have a route to this destination, then the next hop IP address to get to this destination should become a candidate default route”.
Now notice I used the term “candidate default route”. A router may obtain a default route from various sources: statically defined, redistributed from a routing protocol, or via the ip default-network
command. If a router receives multiple such default routes, they are all candidates. But one is chosen, and is indicated by the “Gateway of Last Resort is…” statement in the IP routing table.
You can find more information about this command here:
