I just reading on IPv6 and you discussed converting between binary /decimal to Hexadecimal. You advised to split the 8 bits to 2 nibbles. When I look at the “chart” I’m confused how you come up with the 2 nibbles. From which end of the 8 bits do you write/align the first 4 bits? And how are you obtaining the decimal value. I understand how it works in IPv4 when converting the bit values to decimal but seems confusing when u split to 2 nibbles. thanks
We use four bits (a nibble) since that allows us to create all hexadecimal values:
- 0 - 0000
- 1 : 0001
- 2 : 0010
- 3 : 0011
- 4 : 0100
- 5 : 0101
- 6 : 0110
- 7 : 0111
- 8 : 1000
- 9 : 1001
- A : 1010
- B : 1011
- C : 1100
- D : 1101
- E : 1110
- F : 1111
For example, let’s say you want to convert the decimal value 212 to a hexadecimal value. First we have to convert it into binary:
212: 11010100
Now we can convert it from binary to hexadecimal. We’ll chop it into two nibbles:
1101 = D
0100 = 4
So the hexadecimal value is D4, often represented as 0xD4.
Does this help?
Thank you very much Rene. You are an awe-some instructor/teacher. Never seen anyone as dedicated and responsive to students. I figured how you go about this - Write the binary in nibbles starting from left to right and read the result Top-to-Bottom? Thanks - awe-some!!! Keep up the good work
