IPv6 ND Inspection
Seems to be a typo:
“R1 and R2 are two legitimate devices with IPv6 addresses. I will use R3 to spoof an IPv6 address, SW1 is where we configure ND inspection.”
In the network diagram you have H1 and H2 instead of R1 and R2
Hello Elias
Thanks for pointing that out. I’ll let Rene know…
Hi Community !
I am finding most of the IPV6 first hop security topics (RAGUARD,DHCPGUARD,ND INSPECTION etc) NOT working with Cisco VIRL switch version as below.
Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20180619)FLO_DSGS7
This is a very important MUST PRACTICE topic on the ENARSI exam. please suggest suitable VIRL Cisco image.
Hello Raghu
You are correct. It seems that this particular switch version is behaving strangely. It has the ipv6 nd command available, but if you add anything after that, it says “unrecognized command.”
SW1(config)#inter gig 0/1
SW1(config-if)#ipv6 n?
nd  next-hop-self
SW1(config-if)#ipv6 nd ?
% Unrecognized command
Based on this Cisco learning network thread, others have faced similar situations. Still, others are able to implement RA Guard on this image. According to this documentation, it seems that IPv6 is not supported by this image (even though some of the commands appear!!):
One option is to use the NS-OX v which supports it. The commands are almost the same and the logic is the same. Alternatively, you can try downgrading to the previous IOSvL2 version as some threads state that this may resolve the issue.
Hi Lazaros,
Could you please share the procedure to downgrade cisco Virl Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20180619)
Raghunath
Hello Raghu
Looking a little deeper, I see that someone using vIOS_L2 version 15.2(4.0.55)E was able to get the IPv6 nd ? commands to work. You can see this in the following Cisco learning network thread:
I suggest you go to the CML site where you can download the various vIOS versions available. But you will need a CML subscription to do so.
For detailed information about how to install the vIOS images, you will have to view Cisco’s CML support pages found here:
Thanks for your explanation,
please , what about this section
Let’s get rid of R3 and clean up the policy before we continue: second command
I think , it’s missing "no "
:wink:
Hello Abu
Yes you are correct, thanks for pointing that out! I will let Rene know to make the correction…
In this case, it should be shutdown because I’m getting rid of R3 before we continue. :slight_smile:
It appears that IPv6 inspection is deprecated and replaced with device-tracking commands. When will the course be updated accordingly?
Hello Adil.Nasser
Thanks for your feedback. Yes, indeed, IPv6 inspection has been deprecated, especially on modern IOS-XE platforms (particularly Catalyst 9000 series and later releases for 3850/3650). The IPv6 ND Inspection commands have been deprecated in favor of the Device Tracking feature, which is part of the SISF (Switch Integrated Security Features) framework.
Specifically, IOS 12/15, and early IOS-XE versions used separate commands like ipv6 snooping, ipv6 nd inspection, and ipv6 nd raguard while the modern approach on IOS-XE 16.x/17.x uses unified device-tracking policy-based configuration.
You can find out more about this modern approach here:
In the meantime, I will ask @ReneMolenaar to respond concerning the addition of new lessons to cover these topics.
Always remember however, that you can suggest your own topics at the Member Ideas page below:
I appreciate your quick response and very helpful information. Another question, spurred from your answer, is where is the link to the Member Ideas area from the main NetworkLessions website?
Adil
Hello Adil.Nassr
It is my pleasure to respond to your questions! The Member Ideas page is accessible from the main homepage under the “Courses” menu. It is the last item on the menu titled “Lesson Ideas”.
