Can you please explain how ISP restrict bandwidth to their customer let’s say 10MB.
This is normally done with policing:
Thanks, well explained. the same configuration will work on Vlan as well right ?
How different QoS policing from rate limit option ??
You can also apply this to VLANs yes. The rate-limit command is the old method of policing, using the MQC is the new method.
To limit your traffic, you can also use the srr-queue bandwidth command.
