I’m not understanding the difference between the command:
ip igmp static-oif
and
ip igmp join-group
isn’t these commands similar? the first command binds a group to the OIF whil the 2nd command binds interface to a group. Isn’t that the same thing? I have looked these up in the Cisco command guide but doesn’t really help. How and when would you use one over the other? To me they sound the same and looks like it just preference on which one you want to use.
Just a clarification here. The command ip igmp static-oif is a command found on Nexus devices. The corresponding command on IOS devices is ip igmp static-group.
Now what’s the difference?
ip igmp join-group will cause the interface to actively join a multicast group as a member. That means that the IP address of the interface itself is a receiver of that multicast traffic. The result is an entry in the multicast routing table. The interface is also able to ping the multicast group it has joined.
ip igmp static-oif (or ip igmp static-group in IOS) will cause the interface to enable hardware switching (or fast switching) of that specific group’s traffic without joining the multicast group itself. The result is that the entry appears in the multicast routing table as before, however, you will be unable to ping the multicast group from that interface, since it is not a member.
