I unfortunately did not find a matching lesson, so I’m creating a new topic. NetworkLessons lacks lessons for the following topics:
3.3.a Describe Layer 1 concepts, such as RF power, RSSI, SNR, interference, noise, bands, channels, and wireless client devices capabilities
3.3.b Describe AP modes and antenna types
I have questions regarding watts and decibels. Fortunately, it’s only theory since I understand the calculations.
OCG says the following:
[image removed due to copyright]
I get what’s happening here but not the explanation behind it? If we use the logaritmic comparison function for dB, we will find out what the loss is in dB, which is -65. So what are they trying to tell us in the later paragraphs? What exactly is a better approach? Like they’ve just converted the watts into dBm which makes it easier to work with but what is this page trying to say? I am not quite wrapping my head around it.
The second pages say the following:
[image removed due to copyright]I don’t get the following:
By itself, an antenna does not generate any amount of absolute power. In other words, when an antenna is disconnected, no milliwatts of power are being pushed out of it. That makes it impossible to measure the antenna’s gain in dBm. Instead, an antenna’s gain is measured by comparing its performance with that of a reference antenna, then computing a value in dB.
Nothing generates power when it’s disconnected.. Are they trying to say that the antenna doesn’t produce any power on its own but it rather radiates the power the transmitter sends to it? So we use a different unit here, dBi?
Does it matter which term we use, then? They just calculated the overall power at the EIRP by adding dBms and dBis together.
Also, maybe I am just confused, but when is dB used? If dBm is a power unit relative to the watts, dBi is a unit used to represent gain/loss, what is dB?
That’s all, thank you.
