Hi Networklessions ,
I was trying to form a Layer3 loop , basically i was verifying that how the TTL decrements incase of a loop and finally how the packet will be dropped .
My topology is like below:
L0,1.1.1.1 R1 2.2.2.1-------------2.2.2.2 R2 L0,3.3.3.3
In both RIP version 2 is configured .
In R1 , i added default route next hop pointing R2 , then in RIP i am originating default informations (using command “#default-information originate”) , Finally both routing tables are like below ::
R1#show ip route
C 1.1.1.0 is directly connected, Loopback1
2.0.0.0/24 is subnetted, 1 subnets
C 2.2.2.0 is directly connected, Serial0/0
R 3.3.3.0 [120/1] via 2.2.2.2, 00:00:05, Serial0/0
S* 0.0.0.0/0 [1/0] via 2.2.2.2
R2:
R2#show ip route
R 1.1.1.0 [120/1] via 2.2.2.1, 00:00:14, Serial0/0
C 3.3.3.0 is directly connected, Loopback1
R* 0.0.0.0/0 [120/1] via 2.2.2.1, 00:00:14, Serial0/0
Ping:
R1#ping 8.8.8.8 source loopback 1
My questions is related to ping , when I am initiating a ping to any unknown network using source interface l0 from R1, then only I am seeing ICMP packets are looping and finally dropped with TTL ==0 .
But why there is no loop happening while i used “ping 8.8.8.8” , without source command . Just curious to know
Sameer.
