Hello JP,
You get a RIB failure when BGP can’t install something in the routing table. Usually this happens when you can’t resolve the next hop or when there is another route with a better (lower) AD already installed in the routing table.
Here’s a quick example:
R3#show ip bgp
BGP table version is 2, local router ID is 192.168.34.3
t secondary path,
* 4.4.4.4/32 192.168.13.1 0 1 2 4 i
*> 192.168.34.4 0 0 4 i
R3#show ip route bgp
a - application route
B 4.4.4.4 [20/0] via 192.168.34.4, 00:01:43
Let’s add a static route for 4.4.4.4/32 so BGP can’t install the route in the routing table anymore:
R3(config)#ip route 4.4.4.4 255.255.255.255 192.168.34.5
You now get an error:
R3#show ip bgp
BGP table version is 3, local router ID is 192.168.34.3
t secondary path,
r 4.4.4.4/32 192.168.13.1 0 1 2 4 i
r> 192.168.34.4 0 0 4 i
R3#show ip bgp rib-failure
Network Next Hop RIB-failure RIB-NH Matches
4.4.4.4/32 192.168.34.4 Higher admin distance n/a
