I apologize if this question is naive, but how can leaking specific routes influence incoming BGP traffic?
Hello @jbhosle ,
Not naive at all. With some networking concepts, it can be difficult to wrap your head around it. Here is an example.
Imagine we have three routers: R1, R2, and R3. Connected in a triangle. Each router has its own AS. R1 has a loopback interface with 1.1.1.1/32, which we advertise as a 1.0.0.0/8 summary route.
Here are the configs:
hostname R1
interface GigabitEthernet0/0
interface GigabitEthernet0/1
router bgp 1
bgp router-id 1.1.1.1
network 1.1.1.1 mask 255.255.255.255
aggregate-address 1.0.0.0 255.0.0.0 summary-only
neighbor 192.168.13.3 remote-as 3
hostname R2
router bgp 2
bgp router-id 2.2.2.2
neighbor 192.168.23.3 remote-as 3
hostname R3
router bgp 3
bgp router-id 3.3.3.3
neighbor 192.168.13.1 remote-as 1
neighbor 192.168.23.2 remote-as 2
Here is the BGP table of R2 and R3:
R2#show ip bgp
BGP table version is 5, local router ID is 2.2.2.2
t secondary path,
* 1.0.0.0 192.168.23.3 0 3 1 i
*> 192.168.12.1 0 0 1 i
R3#show ip bgp
BGP table version is 5, local router ID is 3.3.3.3
t secondary path,
* 1.0.0.0 192.168.23.2 0 2 1 i
*> 192.168.13.1 0 0 1 i
As you can see, R2 and R3 both use their link to R1 to reach 1.1.1.1.
Now let’s make a change on R1:
R1(config)#route-map ADVERTISE_SPECIFIC_L0 permit 10
R1(config-route-map)#match ip address R1_L0
R1(config)#ip access-list standard R1_L0
R1(config-std-nacl)#permit host 1.1.1.1
R1(config)#router bgp 1
R1(config-router)#neighbor 192.168.12.2 unsuppress-map ADVERTISE_SPECIFIC_L0
This tells R1 to advertise the specific route 1.1.1.1/32 to R2, next to the summary route.
Clear the BGP neighbor adjacency or do a soft reconfiguration:
R1# clear ip bgp * soft
Now look at R2 and R3 again:
R2#show ip bgp
BGP table version is 6, local router ID is 2.2.2.2
t secondary path,
*> 1.1.1.1/32 192.168.12.1 0 0 1 i
R2 receives the summary route and the specific 1.1.1.1/32 prefix. All is good. Here is R3:
R3#show ip bgp
BGP table version is 6, local router ID is 3.3.3.3
t secondary path,
*> 1.1.1.1/32 192.168.23.2 0 2 1 i
This is not good. R3 uses R2 to get to 1.1.1.1 because this is a more specific route. R2 “leaks” that specific route to R3. Now imagine R3 belongs to a huge ISP and R2 is some small company…
I hope this helps!
