Leaking VRF routes on the same switch
Hi! I am working a 3850 switch running IOS-XE 16.6.2 that has two vrf’s (red01 and blue02). Is it possible to leak routes between the vrf and the global only? The vrf’s can not know about each other - only communicate with the shared vlan.
When I try to follow the static or BGP configurations, I get “its this router” when I try to point the vrf to the shared vlan within the global as its next hop. I can not ping the shared vlan (11.51.100.254) from the vrf or vice versa. What am I not understanding here???
My configuration:
ip vrf red01
ip vrf blue02
int vlan 200
description Shared
ip address 11.51.100.254 255.255.255.0
int vlan 20
ip vrf forwarding red01
ip address 11.61.100.254 255.255.255.0
int vlan 40
ip vrf forwarding blue02
ip address 11.71.100.254 255.255.255.0.0
ip route 11.61.0.0 255.255.0.0 vlan 400
ip route 11.71.0.0 255.255.0.0 vlan 400
ip route vrf red01 0.0.0.0 0.0.0.0 11.40.100.254
ip route vrf blue02 0.0.0.0 0.0.0.0 11.40.100.254
Hello Shannon
I believe the following lesson should answer most of your questions concerning this issue.
I believe that it will probably explain the topics much clearer than an answer in a post on this thread. Take a look and if you have any additional questions, let us know and we’ll help you out!
