Hello All,
I’m Liam. I currently work in a position that requires CCNA, which I have, but need to re-certify soon, thus the reason I’m here. I will work through ICND1 and 2 and ask questions if I don’t understand something, however simple it may be. Much of this knowledge escapes you unless you use it daily.
Hello Liam,
Welcome on board! When you don’t use the things you learned daily, your knowledge will slowly decay
When you go through the material, you’ll get back into it. If you run into anything (new) you have questions about, we are here to help. Good luck studying!
