Very good! Explained in plain english , i wish all IT doc were like this!
Thanks Rene
thank u reneeeeee <3
Thanks Rene for the excellent post. bit confused with the LFIB part how it is being built ? if router is learning the same route from the multiple destinations and they have their own labels imposed on it and advertised to our router in that case how router will decide which one to use ?
Hi Niranjan,
The routing decisions remain the same, we use our routing table for this. Other routers can advertise all the labels they want to us but our local router will decide the path we use, just like with normal routing without labels.
Thanks for a great explanation
Quick question if you do not mind… the prefixes that will be installed on the LFIB, do they need to be learned by the same routing protocol?
I set up the following lab in order to fully understand how it works (I came across a similar setup during one of my mock labs):
Cust1A <-> ISP11 <-> R1 <-> R2 <-> ISP21 <-> Cust1B
- R1 and R2 are running OSPF and MPLS is enabled (they should be the transport network)
- ISP11 and ISP21 are running eBGP with R1 and R2 respectively and MP-eBGP between themselves to exchange VPNv4 prefixes
- VRF Cust1 on ISP11 peers with Cust1A using EIGRP, and the same goes for VRF Cust1 on ISP12 with Cust1b
If ISP11, R1, R2 and ISP12 run a common protocol (let’s say all of them are in OSPF area 0), everything works fine.
I am looking for further details on the Cisco documentation (I believe this scenario is called Inter-AS MPLS topology), but any comments would be more than welcome
Thanks in advance,
C
Hi César,
Do you still have the configs for this setup? I’d like to take a look.
Thanks for your reply
In the end I managed to get it working sending the labels via eBGP:
router bgp 65211
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 10.1.221.221 remote-as 65221
neighbor 10.1.221.221 ebgp-multihop 255
neighbor 10.1.221.221 update-source Loopback0
address-family ipv4
neighbor 10.211.213.213 activate
neighbor 10.211.213.213 send-label
exit-address-family
I still need to read a few documents about this topic, but any comments you might have will be more than welcome
Please, find the topology diagram (my previous one was simplified) and the configuration file
Thanks again for looking into this,
C
lab_config.txt (54.9 KB)
Why LDP uses loop back address to form the LDP neighbors?? It can use the phyiscal interface address as we form LDP neighbor ship with directly connected neigbhors only in most of the cases
Hi Venkata,
This is explained in the following topic:
Good Day and thanks for your patience to write down valuable and depth discussion in important key point in the computing data communication.
I started study mpls in your document but I have curiosity, how mpls protocols is faster than traditional ospf , is-is,eigrp and so many.
It’s label switching but still using igp routing for label switching PE to PE, So I studied cisco and online documents but i am not that much clear , they said packet strip only one time for final destination then level switched until the destination PE router.
Can you send or post me some discussion about traditional routing systems and mpls mechanism. I am expecting your clear discussion or reference.
Thanks for your good cooperation.
Hi MD Arif T,
The main difference is that:
- In MPLS we are switching based on labels.
- In IP we are routing based on destinations.
Theoretically doing lookups for labels is faster than lookups in the routing table for destinations. I doubt there is much of a performance different nowadays though…keep in mind that MPLS is > 15 years old, back then it might have made more of a difference.
The main advantage of MPLS is that we are able to transport non-IP traffic and we have VPNs.
Ciao Rene’,
I really love the way you explain networking topics
just one clarification, to be sure that I’ve properly understood. Some paragraphs before you wrote:
“Since the LIB is built with information from the RIB, we will start with the routing table. Here’s R1”
in this case wouldn’t be more appropriate to show the data from RIB more than the routing table?
Thanks in advance for your answer
Salvatore.
Hello Salvatore,
Glad to hear you like it ![]()
When I’m talking about the RIB (Routing Information Base), then I refer to the global routing table (show ip route). There are some discussions about this as some people don’t see this as the RIB.
The way I see it is that different routing protocols have their own “tables”:
- BGP: BGP Table
- OSPF: LSDP
- RIP: Database
The best routes (based on administrative distance) from different routing protocols are placed in the RIB (routing table), and that’s it. Sometimes people like to call the BGP table the BGP “rib”, the OSPF LSDB the “OSPF RIB” etc. This is confusing.
I was reviewing Keith Barkers MPLS course and I was a bit confused on one of his “opt out” questions. Which was “LDP and OSPF are both which type of protocols?”. So far the only thing I’ve been able to come up with would be, Link-State. Since they both build adjacencies based on hellos and also both build thier own tables… Would you agree?
Hi Jonathan,
That is a good question…LDP isn’t a link-state protocol though.
The only similarities I can think of are:
- OSPF and LDP both use the highest IP address on a loopback interface as the router ID.
- Both protocols advertise "something". OSPF prefixes and LDP labels.
Thanks for the nice readup.
Though i have not fully understand the workings of MPLS, it seems like the LABELs are build from the routing information available in the routers. (RIB to LIB).
As we know for when multiple routes are available to the similar destination, the route with the least ad/cost is use for routing.
But how about MPLS? how does LDP choose which LABEL to put into the LFIB ?
Alan
Hi Alan,
That’s correct. The information in the RIB is used to build the LIB.
LDP won’t “choose” any routes by itself. The best routes were installed in the routing table and that’s what we will use. For the prefixes you will find in the routing table we will use labels, that’s it.
Thanks for your reply.
As you mentioned, information inside the RIB is use to build the LIB.
So i would imagine to have a LABEL for all the available routes.
e.g. I have 3 best routes to the same destination with rip, eigrp, ospf in the RIB.
192.168.0.0/24 via 192.168.1.1 - rip
192.168.0.0/24 via 192.168.2.1 - eigrp
192.168.0.0/24 via 192.168.3.1 - ospf
q1) Can i check for FIB, does it contain the same amount of available routes as in the RIB ?
q2) if the above is yes, i would believe FLIB and FIB would have the same amount of labels ?
q3) it is said that in MPLS, the LABELs are use to do switching/routing from Source to Destination and it is faster because there is no need to do best route selection using the IP headers. – is this true ?
But how do we ensure that the LABELs being used (added) and the next hop to send to represent the best routing path available ?
or to put it in another way
- in normal routing, best route selection is done via (ad, metric, prefix length)..
- in mpls, since all available routes will have a tag, how does the router know which tag to use (without looking at the routing table for the best route) ?
Alan
Hi Alan,
If OSPF, EIGRP and RIP have learned the 192.168.0.0/24 route then only one will be installed in the routing table. EIGRP will be selected since it has the lowest administrative distance.
By default, LDP will generate a label for each route in the routing table. This is something that you can change by using access-lists if you want.
The LFIB has pretty much the same information as the FIB, however some entries in the FIB (like directly connected interfaces) won’t show up in the LFIB.
Theoretically, switching based on labels is faster than routing where we do a lookup for the IP destination. Nowadays this doesn’t matter much. Keep in mind MPLS is already quite old.
The RIB only has the best routes in it, the FIB is built with information from the RIB. That’s why you know that we also use the best path with label switching. Labels are advertised between routers, that’s how they know which label to use.
If you want to see this in action, boot a couple of routers and configure OSPF on EIGRP on them…advertise some loopbacks. Then enable MPLS on the interfaces and take a look at the different tables:
- show ip route = RIB
- show ip cef = FIB
- show mpls ldp bindings = LIB
- show mpls forwarding-table = LFIB
