Mpls pe/ce
I should say that your site really helped me a lot in getting my CCNP. Big Thanks!
Regarding the lab above, i am just quite puzzled why I am unable to ping CE2 (5.5.5.5) from CE1 (1.1.1.1)
I checked thoroughly the configs and it seems no difference
Below is my routing table from my PE1 and could see that i could reach via my GRE Tunnel although when i checked the CEF Table it still goes to my P router.
B       1.1.1.1 [20/0] via 192.168.12.1, 02:00:39
C       2.2.2.2 is directly connected, Loopback0
O       3.3.3.3 [110/11] via 192.168.23.3, 00:16:25, FastEthernet0/1
O    192.168.45.0/24 [110/30] via 192.168.23.3, 00:16:25, FastEthernet0/1
O       4.4.4.4 [110/21] via 192.168.23.3, 00:16:27, FastEthernet0/1
<strong>C    192.168.24.0/24 is directly connected, Tunnel0
B       5.5.5.5 [200/0] via 192.168.45.5, 00:16:21</strong>
C    192.168.23.0/24 is directly connected, FastEthernet0/1
O    192.168.34.0/24 [110/20] via 192.168.23.3, 00:16:28, FastEthernet0/1
PE1#show ip cef 5.5.5.5
5.5.5.5/32, version 39, epoch 0, cached adjacency 192.168.23.3
0 packets, 0 bytes
  via <strong>192.168.45.5</strong>, 0 dependencies, recursive
    next hop 192.168.23.3, FastEthernet0/1 via 192.168.45.0/24
    valid cached adjacency
Hi Eleever,
Good to hear my work has been useful to you :slight_smile:
Your PE1 router is using 192.168.45.5 as the next hop for 5.5.5.5.
192.168.45.5 is reached by using 192.168.23.3 as the next hop, that’s your P router.
You need to make sure that your PE1 (and PE2) router prefers to use the tunnel interface. You could do this by playing with the metric, administrative distance or filtering.
