have you configured Iperf as VM / please let me know how did you use iperf for this demonstration
Hello Viki
In this particular lesson, Rene has simply described how to set up the MQC traffic shaping example. He didn’t actually run any traffic through the shaper in the lesson. However, you can run Iperf on many different platforms, (either VM or otherwise) to do such tests. Take a look at the following lesson for an example of how it has been used:
Actually, you can also install it on a Cisco IOS-XE device as well, since it is also based on Linux.
Hello Guys,
Looks like the next topic in QoS Shaping is missed/ removed from your platform by this title name “How to test if your ISP shapes your traffic.”, would you double check and update it. Thanks
Nahro Ghafoor
Hello Nahro
Thanks for pointing that out! I will let Rene know to make the appropriate modifications.
Thanks again!
