Multicast Routing
Rene: multicast ip range is 224.0.0.0 - 239.255.255.255, i think you had a typo under the “administrative scoping” ??
Correct me if i am wrong. Thanks
Hi Siva,
That’s the entire multicast range (class D) but the administratively scope is the range from 239.0.0.0 through 239.255.255.255.
You don’t want to filter the 224.x.x.x range, this is also used by protocols like OSPF, EIGRP, HSRP, VRRP, etc.
Clear explanation.
Thanks Rene.
Davis
hi, it’s good to understand concept of multicast
i have one question,
if shared tree path is equal to shortest tree path(first hop router is rp) , dose the last hop router send s,g join message to first hop router(RP) ?
when spt-threshold is set to infinity, does it work efficiently than now applied?
Absolutely sound tutorial !
Just a small observation…
When the TTL value of the IP packet is below or equal to the threshold then the packet will be forwarded dropped, otherwise it will be forwarded.
Ody
Hi Ody,
I just changed it to:
When the TTL value of the IP packet is equal or greater than the threshold then the packet will be forwarded, otherwise it will be discarded.
When the TTL is equal to the threshold, it will be forwarded.
Excellent explanation, thanks Rene. Finally I am getting dense and sparse mode
thanks a ton.
so there are multiple ways multiple protocols to achieve multicast in a network .
but talking about today’s real time network , is it correct to say that PIM SPARSE MODE is popular and mostly seen.
Dense-Mode is never used except maybe as a troubleshooting step. For IGMP v1 and v2 that only leaves Sparse-Mode. However, there are a lot of advantages to using Source Specific Multicast (SSM) (no need for a rendezvous point!), but this is only available via IGMP v3. I would say certainly any new implementation of multicast would use SSM if possible, but whether there are actually more sparse-mode vs SSM, I would save given that IGMP v2 has been around longer, Sparse-Mode might be the more common.
Hi Rene/Andrew,
Can you please help in understating when multicast-routing distributed needs to be used ? I read reference of stackable switches.
So is it mandatory that if we have stacked swithces which are participating in L-3 routing , we must use multicast-routing distributed instead multicast-routing ?
Abhishek
Hello Abhishek!
The main purpose of the multicast-routing distributed command is to take advantage of the Multicast Distributed Switching (MDS) functionality that is available on high end Cisco L3 switching devices. MDS is accomplished using a forwarding data structure called a Multicast Forwarding Information Base (MFIB), which is a subset of the routing table. The multicast-routing distributed command essentially enables multicast routing on an L3 device. There is no alternative multicast-routing command. Counterintuativly, the distributedkey word indicates that distributed SWITCHING be taken advantage of in the multicast routing process.
As for stackable switches, there is no specific configuration considerations when configuring multicast routing. The only thing that should be taken into account is the fact that it is the master switch that performs the following in multicast routing:
•It is responsible for completing the IP multicast routing functions of the stack. It fully initializes and runs the IP multicast routing protocols.
•It builds and maintains the multicast routing table for the entire stack.
•It is responsible for distributing the multicast routing table to all stack members.
The stack members perform these functions:
•They act as multicast routing standby devices and are ready to take over if there is a stack master failure. If the stack master fails, all stack members delete their multicast routing tables. The newly elected stack master starts building the routing tables and distributes them to the stack members.
•They do not build multicast routing tables. Instead, they use the multicast routing table that is distributed by the stack master.
For more information about distributed switching and multicast routing using stacked L3 switches, take a look at the following Cisco support document:
Thankyou Laz. great explanation.
While working in LAB i noticed, 3750 has this distributed keyword available but not 3850. Looks like Cisco has enabled MDS enabled by default.
abhishek
Hello Abhishek
Yes, it seems that way. It also depends on the IOS version that is being used on each platform.
What is the meaning of (*, X.x.x.x) in multicast routing table.
Hi Mohammad,
The x.x.x.x is the multicast group address and the * depends if you are using PIM dense or PIM sparse mode.
I covered both in these lessons with an explanation of how the multicast routing table works:
https://networklessons.com/ciscoccie-enterprise-infrastructuremulticast-pim-sparse-mode/
Can you explain in detail about the VRF aware Multicast…
Hi Sushanth,
The multicast commands can be enabled per VRF. Here is a quick example of two routers and two VRFs, RED and BLUE.
R1 has two loopback interfaces, one for each VRF. The IP addresses on the loopback interfaces are used as the RP address.
R1:
hostname R1
ip vrf BLUE
 rd 20:20
ip vrf RED
 rd 10:10
ip multicast-routing vrf RED
ip multicast-routing vrf BLUE
ip cef
interface Loopback1
 ip vrf forwarding RED
 ip pim sparse-mode
interface Loopback2
 ip vrf forwarding BLUE
 ip address 11.11.11.11 255.255.255.255
 ip pim sparse-mode
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip pim sparse-mode
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.21.1 255.255.255.0
 ip pim sparse-mode
router eigrp 1
 address-family ipv4 vrf BLUE autonomous-system 21
  network 11.0.0.0
  network 192.168.21.0
 exit-address-family
 address-family ipv4 vrf RED autonomous-system 12
  network 1.0.0.0
  network 192.168.12.0
 exit-address-family
ip pim vrf RED rp-address 1.1.1.1
ip pim vrf BLUE rp-address 11.11.11.11
R2:
hostname R2
ip vrf BLUE
 rd 20:20
ip vrf RED
 rd 10:10
ip cef
 ip pim sparse-mode
 ip address 192.168.21.2 255.255.255.0
 ip pim sparse-mode
interface GigabitEthernet0/2
 no ip address
router eigrp 1
 exit-address-family
 exit-address-family
Now you can use the same multicast commands but include the VRF.
VRF RED:
R2#show ip pim vrf RED rp
Group: 224.0.1.40, RP: 1.1.1.1, uptime 00:03:04, expires never
VRF BLUE:
R2#show ip pim vrf BLUE rp
Group: 224.0.1.40, RP: 11.11.11.11, uptime 00:03:07, expires never
Above we see the RP, one for each VRF. Here are the multicast routing tables.
VRF RED:
R2#show ip mroute vrf RED
IP Multicast Routing Table
   G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
   N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
   Q - Received BGP S-A Route, q - Sent BGP S-A Route,
   V - RD & Vector, v - Vector, p - PIM Joins on route,
   x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
 Timers: Uptime/Expires
(*, 224.0.1.40), 00:03:26/00:02:14, RP 1.1.1.1, flags: SJPCL
  Incoming interface: GigabitEthernet0/1.10, RPF nbr 192.168.12.1
  Outgoing interface list: Null
VRF BLUE:
R2#show ip mroute vrf BLUE
   x - VxLAN group
(*, 224.0.1.40), 00:03:29/00:02:16, RP 11.11.11.11, flags: SJPCL
  Incoming interface: GigabitEthernet0/1.20, RPF nbr 192.168.21.1
Hello Rene, your explanations and examples are always helpful ! One confusion i am having is that every packet has a destination of multicast address ! There is a multicast group which i meed to understand in detail ! I mean where is this destination located ? And why we use multicast group instead of destination ?
Means in unicast table, there is one source and one destination ! Why in multicast we use group ! Please explain in easy english as always :slightly_smiling_face:
