I need to configure netflow on the Cisco ASA firewalls. We have Riverbed Cascade gateways that the routers send flows and the gateways, after de-duplication, send the flows to the Profiler to display. I did not see any configuration about the netflow on the ASA that I could use for testing. We have something similar configured on our routers, but the ASA does not support most of the commands, like the collect command. Here is what I would like to use and would like someone from the group to take a look at it:
flow-export destination inside 10.65.63.151 4000
flow-export template timeout-rate 15
flow-export active refresh-interval 30
flow-export delay flow-create 10
class-map flow-export-class
match any
policy-map global_policy
class flow-export-class
flow-export event-type all destination 10.65.63.151
Since we already have a global policy-map I need to embed the class-map into the existing policy-map
