Hey, I have some questions over OSPF hello and Immediate hello,
My lab is as such
R1 GI1- R2 GI1
R1- GI1 , netwrk type point to point, Hello: 5 sec, Dead 20 sec
r1#sh ip ospf int
GigabitEthernet1 is up, line protocol is up
Internet Address 12.12.12.1/24, Interface ID 7, Area 0
Attached via Interface Enable
Process ID 1, Router ID 1.1.1.1, Network Type POINT_TO_POINT, Cost: 1
Topology-MTID Cost Disabled Shutdown Topology Name
0 1 no no Base
Enabled by interface config, including secondary ip addresses
Transmit Delay is 1 sec, State POINT_TO_POINT, BFD enabled
Timer intervals configured, Hello 5, Dead 20, Wait 20, Retransmit 5
r1#
*Jul 22 08:00:11.285: OSPF-1 HELLO Gi1: Rcv hello from 2.2.2.2 area 0 12.12.12.2
*Jul 22 08:00:13.380: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1
Question 1: is this a reply to the Rcv hello sent 08:00:11.285? or it’s a hello initiated by this R1? Is it required for the receival of Hello to acknowledge? I supposed hello can be sent by both peers, is that why I’m seeing Rcd and Send?
Question 2: what is immediate Hello?
I configured an acl on R1 G1 to deny OSPF traffic,
r1#sh access-list 110
Extended IP access list 110
10 deny ospf any any
20 permit ip any any
r1#conf t
OSPF peer down the moment I applied it and when I removed it, I could see there’s a Immediate Hello. The interval between the 1st Hello Sent and 2nd Hello sent by R1 is not with 5 seconds interval however, see 08:05:04.116 and 08:05.04.930. Can you advise what is this Immediate Hello, is this a hello initiated from R1 or reply to R2 since I can see R1 received hello at 08:05:04.930 also. Thanks a lot
*Jul 22 08:05:04.116: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1
*Jul 22 08:05:04.930: OSPF-1 HELLO Gi1: Rcv hello from 2.2.2.2 area 0 12.12.12.2
*Jul 22 08:05:04.930: OSPF-1 HELLO Gi1: Send immediate hello to nbr 2.2.2.2, src address 12.12.12.2
Full debug logs:
r1(config-if)#
*Jul 22 08:04:40.688: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1
*Jul 22 08:04:45.505: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1
*Jul 22 08:04:46.339: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.2 on GigabitEthernet1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Jul 22 08:04:46.339: %BFD-6-BFD_SESS_DESTROYED: BFD-SYSLOG: bfd_session_destroyed, ld:4097 neigh proc:OSPF, handle:1 act
r1(config-if)#
*Jul 22 08:04:50.111: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1
r1(config-if)#
r1(config-if)#do sh ip ospf ne
*Jul 22 08:04:54.729: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 ip access-group 110 in
*Jul 22 08:04:59.269: OSPF-1 HELLO Gi1: Send hello to 224.0.0.5 area 0 from 12.12.12.1no ip access-group 110 in
r1(config-if)#
*Jul 22 08:05:04.930: OSPF-1 HELLO Gi1: Send hello to 12.12.12.2 area 0 from 12.12.12.1
*Jul 22 08:05:04.934: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.2 on GigabitEthernet1 from LOADING to FULL, Loading Done
*Jul 22 08:05:04.946: %BFD-6-BFD_SESS_CREATED: BFD-SYSLOG: bfd_session_created, neigh 12.12.12.2 proc:OSPF, idb:GigabitEthernet1 handle:1 act
*Jul 22 08:05:05.346: %BFDFSM-6-BFD_SESS_UP: BFD-SYSLOG: BFD session ld:4097 handle:1 is going UP
