OSPF Non-Broadcast Network Type over Frame-Relay
Hello!
Make sure you have a frame-relay map statement with the broadcast keyword or you won’t be able to send multicast on your frame-relay network.
I can’t clearly understand the purpose of broadcast key word in dlci mapping (if inverse arp is disabled), because we are talking about NON-BROADCAST.
Is it right that this key word allows hub router to duplicate multicast ospf frames and send them to unicast addresses (that were configured by neighbor command)?
Hello Artem
Yes you are correct, that frame relay is a non-broadcast network type. This means that any broadcast OSPF packets that arrive at the hub must be propagated in the network. This can be done in one of two ways:
  1. Using the broadcast keyword on the frame relay maps. This essentially forwards any broadcast packets that have been received by the hub router to the IP address specified in the frame relay map as unicast packets. If the broadcast keyword is not there, no forwarding of broadcast packets will be performed, thus OSPF will not be able to send updates.
Yes that is correct.
  1. Inverse ARP. Inverse ARP when enabled will ask the “other end” what it’s IP address is. This allows dynamic mapping rather than static frame relay maps. If you have a static mapping with broadcast, you can safely turn off inverse arp.
Thanks for the answer!
But I have one more question, it’s about BROADCAST network type and Frame Relay encap.
So it is clear for me now that in NON-BROADCAST network hub router will send ospf unicast packets to neighbors and hence it will use a certain DLCI of a certain neighbor on layer 2.
I’ve just tried the same topology as in the lesson(broadcast network type) in gns3 to figure out what dlci number will be in ospf multicast packet. But for some reason gns indicates that packets are encapsulated in HDLC (???),
So the question is: what DLCI number will the router put in frame relay header?
Hello Artem
By default, the encapsulation on a serial interface is HDLC. This means that if you don’t configure frame relay encapsulation, HDLC is what will be used. Are you sure you’ve successfully enabled frame relay encapsulation using the encapsulation frame-relay command on that specific serial interface? You might want to check that out.
As for the DLCI number used, let’s assume the following topology:
R1 ---------------dlci 122-------------- ---------dlci 221--------------R2
When R1 sends information to R2, it encapsulates the PDU using 122 as the DLCI or layer 2 address. This is the case even though the DLCI of the destination is 221. DLCIs are locally significant. R1 knows nothing of the DLCI that R2 is using.
Hi Laz
You say this:
“The next two types of network are used to accommodate multi access technologies that don’t support broadcast. These technologies include Frame Relay and ATM.”
Yet in the Broadcast lesson, you use frame relay?
https://networklessons.com/cisco/ccie-enterprise-infrastructureospf-broadcast-network-type-over-frame-relay/
Hello Chris
Yes, I should clarify. Unlike Ethernet, Frame Relay is a Non Broadcast Multi Access (NBMA) network type. This means that it does not inherently support broadcasts. That is, there is no broadcast mechanism in the technology. So what has to be done is broadcast must be simulated over frame relay in order for OSPF to function correctly.
The serial interfaces used in the configuration are by default set to “point to point” network type. The ip ospf network broadcast command tells the router to treat the specific interface as a broadcast network type for OSFP, thus DRs and BDRs will be elected automatically and neighbour relationships will also be formed automatically. Because frame relay doesn’t support pure broadcast, it simulates a broadcast with multiple unicast packets to the destinations.
Personnaly ; I got a little bit confused about the mapping possibilities between OSPF and Frame-Relay. Drawing the table below does help me get a better understanding of the subject.
Hi Rene, I did the same configuration like you, I have full router neighbor relationship, but spoke1 can’t ping spoke2, can you please help me with this.
Hello Khan,
Do you have a frame-relay map statement on spoke1 for the IP address of spoke2 and another one on spoke2 for the IP address of spoke1?
Something like:
Spoke1
interface Serial 0/0
frame-relay map ip 192.168.123.3 201
Spoke 2:
frame-relay map ip 192.168.123.2 301
Thank you Rene it is working now!!!
You said " This is where things can get funky! If we select the non-broadcast network type we are telling OSPF our network is multi-access but in reality it’s not…"
How we can tell a non broadcast network is a multi access network
Hello Sims
A non broadcast network is one that uses technologies (such as Frame Relay) that do not support broadcast communication. Typically, non-broadcast technologies are not multi-access, since multi-access requires the functionality of broadcasts to operate.
So Frame Relay and other such technologies are never multi-access, like Ethernet is for example. They are based on point to point connections.
However, when you have a frame relay topology, such as this one, you may want OSPF to behave as if it is a multi access network. This is useful when we have a hub and spoke topology which mimics a multi access network without the broadcast functionality. This means that OSPF will expect to have a DR and BDR elected, but will expect us to manually configure them as well as the neighbour adjacecies.
as I read 6 Lessons of OSPF Network types and all topics are related to Frame-relay.
Frame-relay is not being used in my daily work so These network types are related to frame-relay or I will see these networks in other circuit type also
Please let me know
Hello Kunal
The truth is that Frame Relay is not in widespread use anymore, however, OSPF network types are. They are not used very often in the real world, however, their existence should be known and understood.
Frame relay is the main network technology that is used with OSPF network types, however, other such technologies include ATM, X25 and home powerline networks. These too are quite limited in their use, however, once again, OSPF accommodates them and we must know these capabilities of OSPF.
Ok it is working, but why if the inverse-arp is enabled.
And after that i saw too that in the hub router the neighbor commands are not necessary to add the loopback that i’ve propagated on spoke1 and spoke2.
Hello Giovanni
Take a look at this post, it may be helpful…
The key here is that Inverse-ARP only provides frame relay mappings between the hub and each spoke, but not between the spokes themselves. This is why manually configured frame relay maps are the solution here.
In the document you mentioned:
There’s also a command you can use on the Hub router to make sure a spoke router never becomes a DR or BDR. Type in neighbor priority 0 and you are done. You have to do this under the OSPF process.
However in Nabrik Kocharian’s CCIE official guide I read that it’s actually not the case. As I understand it, OSPF process neighbor priority command is somewhat local to the router itself, in our case the Hub router. The router performs the DR/BDR election with non-zero priority neighbors and when the election is completed, then it’ll start sending Hellos to the others. Also the default priority in neighbor command is actually 0, so this command does not really have any direct impact.
Here is a related Cisco community case:
Hi Haniyeh,
You are right. When I wrote this a few years ago, I think I tested it real quick or looked at the command reference:
Priority: (Optional) A number that indicates the router priority value of the nonbroadcast neighbor associated with the IP address specified. The default is 0. This keyword does not apply to point-to-multipoint interfaces.
This is interesting though, there is more behind this command than you would think. I removed the sentence from this lesson. Thanks for sharing those links.
Hi Lazaros,
I am totally confused about these network types broadcast, non- broadcast multi access and so on..
I think Rene should have explained them before starting the main topic OSPF non- br…
Would you please explain them one by one with examples?
Hello Muhammad
OSFP network types are a special case of OSPF implementation. They are used in order to accommodate specific technologies such as frame relay. It is for this reason that they are only described after the main topic of OSPF.
In any case, the reason they exist is that technologies such as frame relay cannot support broadcast and multi access infrastructure, which are prerequisites for normal OSPF functionality. The various types of networks are used to allow OSPF to have DR and BDR elections as well as to form neighbor adjacencies even without broadcast and multicast functionality. Here is a brief summary of these network types and when they should be used:
The following list explains the characteristics of the OSPF network types:
Broadcast - Used on normal Ethernet networks
  • The Broadcast network type is the default for an OSPF enabled ethernet interface.
  • The Broadcast network type requires that a link support Layer 2 Broadcast capabilities.
  • The Broadcast network type has a 10 second hello and 40 second dead timer.
  • An OSPF Broadcast network type requires the use of a DR/BDR which are automatically elected.
Non-Broadcast - used for frame relay physical interfaces
  • The Non-Broadcast network type is the default for OSPF enabled frame relay physical interfaces.
  • Non-Broadcast networks requires the configuration of static neighbors because broadcast traffic cannot be sent
  • The Non-Broadcast network type has a 30 second hello and 120 second dead timer.
  • An OSPF Non-Broadcast network type requires the use of a DR, but the hub must always be DR for it to work so the spokes should have a priority of 0
Point-to-Point - used between two directly connected routers regardless of the technology used
  • A Point-to-Point OSPF network type does not maintain a DR/BDR relationship.
  • The Point-to-Point network type has a 10 second hello and 40 second dead timer.
  • Point-to-Point network types are intended to be used between 2 directly connected routers.
Point-to-Multipoint - used for frame relay with the broadcast keyword for frame relay maps
  • OSPF treats Point-to-Multipoint networks as a collective of point-to-point links, thus no DR/BDR elections take place.
  • Point-to-Multipoint networks do not maintain a DR/BDR relationship.
  • Point-to-Multipoint networks will have an automatic neighbor discovery, so no need to manually configure them.
  • The Point-to-Multipoint network type has a 30 second hello and 120 second dead timer.
Point-to-Multipoint Non-Broadcast - non broadcast layer 2 topologies
  • Same as Point-to-Multipoint but requires static neighbors. Used on Non-broadcast layer 2 topologies.
  • Gives you the ability to define link cost on a per neighbor basis.
A more detailed description of each type is given within the lesson for each one.
