When we need Point to multipoint and Point to multi point non- boradcast
This will depend on the underlying Frame-Relay network. When broadcasting is disabled you will have to use the “non-broadcast” network types.
i just dont understand why broadcasting would be disabled? isnt it just a pseudo broadcast for discovering neighbors? I mean does it congest the network or something?
Hi David,
Broadcasting is a very inefficient method for communication. Imagine you had 200 routers and only 10 of them would talk OSPF. When you send a broadcast it means everyone receives it…whether you want it or not. It’s a waste of bandwidth and resources…
I thought we could disable/enable broadcast - on a frameRelay multipoint interface - per PVC by using the Frame-Relay map ip “IP address” “PVC No.” [broadcast] command. So, If I have 200 routers only 10 speak OSPF why Wouldn’t I disable broadcast on the 190 PVCs and enable it on only 190 routers? The only downside of this is having to entre so many lines of mapping. My point is it is technically possible.
Hoss
Technically it’s possible ![]()
Hi Renee
“There are a couple of things that you need to be aware of:
No Automatic neighbor discovery so you need to configure OSPF neighbors yourself!
No DR/BDR election since OSPF sees the network as a collection of point-to-point links.
Only a single IP subnet is used in the topology above.”
Seems to me I have to commit them to memory.
I have to say them out loud day in and day out like a mantra.
I am asking whether or not there is a rhyme or reason to help me memorize or understand them.
In case of PMNB (point to multipoint nonbroadcast) DLCI’s are not configured?
Hi Lee,
I don’t have a rhyme but there’s some logic to these OSPF network types:
Only broadcast and non-broadcast require a DR/BDR election since OSPF sees these network types as “multi-access”. Everything with “point” in it is seen as a collection of point-to-point links so there is no DR/BDR election.
Everything with “non-broadcast” requires you to configure neighbors since OSPF won’t be able to find them by itself.
Only with point-to-point we use a subnet for each PVC, all other OSPF network types usually have a single IP subnet.
Still some memorization to do but if you understand the logic, it will be easier to remember ![]()
Configuring DLCIs doesn’t have anything to do with OSPF or its network types but when you configure frame-relay, you always need DLCIs…maybe you get one from the frame-relay switch or you have to do it yourself.
Hi, Rene
I hope you are doing great.
I have one question:
- why are you using the command network in order to auto discover the neighbors If you are statically defining them with the command neighbors ?
Have a great day.
Hi Miguel,
I’m doing great, thanks for asking! Hope you as well.
The neighbor command is used to statically configure a neighbor but it doesn’t activate OSPF on an interface. Without the network command, OSPF will never send hello packets on the interface and the routers won’t become neighbors…with or without the neighbor command.
Just an observation, but I think one thing that sets your site apart from others is that you separate lessons like point to point and point to multi-point. Rather than trying to explain them in one lesson going back and forth between each configuration through out the explanation.
This way is very clear, very nicely done!
Chris
Hi Chris,
Thanks for your kind words!
I think it’s important to break things down in smaller pieces, if you have to jump from one config to another then things get confusing. It’s easier to start with a blank slate and then try each network type one-by-one ![]()
hi rene, awesome lessons, i now able to understand clearly the network types. Also notice here that the hello timer just went up to 30seconds.
Hi John,
Glad to hear you like it. OSPF will change its timers based on its OSPF network type ![]()
You do not configure OSPF neighbors in spoke routers so how can they advertise networks to hub router since the network is non-broadcast ??
Hi Hussein,
If you configure the neighbor command on the hub then the spoke routers will receive it and a neighbor adjacency will be formed.
Thanks Rene,
Now everything is clear to me
Hi Ajith,
Thanks, this can be pretty confusing. Most of these network types were used for certain types of networks like hub-and-spoke frame relay with or without broadcast capability.
On regular Ethernet interfaces you don’t really have to bother with choosing different OSPF network types. One of the few protocols where you still have to think about this is DMVPN, which also offers a hub and spoke topology like frame-relay.
Thank You Rene, Your tutorial on Broadcast, Non-broadcast, Multi point are Brilliant.
Now I am able to Discern.
