hi
just confirming if
switchport port-security aging type inactivity
switchport port-security aging time 2
and
errdisable recovery cause psecure-voilation
are supported in packet tracer??i cant see these commands in packet tracer Thanks
hi
just confirming if
and
Hello Sumant
I can confirm that the 3560 24PS Layer 3 switch found in version 7.1.1 of Cisco Packet Tracer does not support the “aging” keyword in the port-security parameters of the device. Nor is is the errdisabled set of commands available either.
In order to examine and use these commands, you will have to find another option such as GNS3 or Cisco Virl.
I hope this has been helpful.
