I have read your lesson on Cisco ASA NAT Forwarding single ports through an ASA.
We have a phone system server that will require a range of ports opening to it from outside.
e.g. we will need to forward udp ports 9000 to 9500 to a single host on the inside.
Can you advise me on how the CLi will be different to port forwarding a single port. Also does the Access List command change as well.
Thanks for your help I have another question if you could help me.
We have a phone server whose local IP Address is say 10.2.50.110 and we want to do the following:
Make it so that the phone server only communicate’s outside using a different public IP 195.66.240.10 this is different from the public IP on the outside interface.
Set-up port forwarding so that the following ports udp/9000-9500, udp/5060 are forwarded using the above public IP Address.
