Hi
I have a scenario as follows:
ip vrf vrf-A
rd 1:1
route-target both 1:1
route-target import 1:2
ip vrf vrf-B
rd 1:2
route -target both 1:2
route-target import 1:1
int vlan111
ip forwarding vrf vrf-A
ip add 10.222.247.6 255.255.255.248
no shut
int vlan222
ip forwarding vrf vrf-B
ip add 10.222.247.10 255.255.255.248
no shut
router bgp 1
address-family ipv4 vrf vrf-A
redistribute connected
redistribute static
exit-address-family
router bgp 1
address-family ipv4 vrf vrf-B
redistribute static
exit-address-family
ip route vrf vrf-A 10.138.240.0 255.255.248.0 vlan111 10.222.247.2
ip route vrf vrf-B 10.138.246.0 255.255.255.0 vlan222 10.222.247.14
> # show ip route vrf vrf-A 10.138.246.0 255.255.255.0
> Routing Table: **vrf-A**
> Routing entry for **10.138.246.0/24**
> Known via **"bgp 1"**, **distance 20**, metric 0, type external
> Last update from 10.137.247.9 on VlanY, 0d2h ago
> Routing Descriptor Blocks:
> * **10.222.247.9 ( vrf-B)**, from 0.0.0.0, 0d2h ago, via **Vlan222**
> Route metric is 0, traffic share count is 1
> AS Hops 0
> MPLS label: none
> MPLS Flags: NSF
vrf-A reaches the network 10.138.246.0 /24 only via VRF vrf-B (BGP), while there is a static route to summary subnet as mentioned above.
10.138.246.0/24 is included in the summary subnet 10.138.240.0 /21
when adding a static route to the specific network:
# ip route vrf vrf-A 10.138.246.0 255.255.255.0 vlan111 10.222.247.2
things become fine as following:
> # show ip route vrf vrf-A 10.238.246.0 255.255.255.0
> Known via **"static"**, distance 1, metric 0
> Redistributing via bgp 1
> Advertised by bgp 1
> * **10.222.247.3, via Vlan111**
ANY body have any idea why is that happening??
_
thanks,
