I think there is a mistake for the Len function it is a copy of the Concatenate function. Also. thanks so much for the lesson!
Hello Justin
Yes, you are correct, thanks for pointing that out. I will let Rene know to make the appropriate changes.
Thanks @Jallen.jaxit, I fixed this.
thanks for your effort to get things easier, But the code of the lesson"Convert data type into list" does not exist , could you put it again or even screen shoot
thanks
Hello Amina
Taking a look at this section of the lesson, I see that the code is displayed correctly:
Can you let us know under what circumstances you can’t see it so that we can fix it if there is a problem?
Hello Lazaros,
thanks a lot ![]()
