Question about MPLS vpnv4 prefix default advertisement
Hi guys, I´ve a question about the default route advetisement under MPLS backbone.
The client A (vrf_a) only has static routing at both sites (X, Y) in my MPLS backbone, he needs to advetise the static route 0.0.0.0/0 from site X to site Y but it doesn´t propagate to the rest of MPLS network, why?
this is my configuration:
router bgp 22345
 rd 22345:800
  address-family ipv4 unicast
   redistribute connected
   redistribute static
router static
 vrf vrf_a
   0.0.0.0/0 10.21.200.186 description default_route
   192.168.201.0/24 10.21.242.186 description LAN_MATRIZ
only the specific route 192.168.201.0/24 is propagated, but the default 0.0.0.0/0 doesn´t.
Only if I set the command default-information originate under BGP vrf_a instance the default route is propagated, why? is this a correct behavour?
Please your feedback.
Thanks in advance.
Hello Javier
In your case it looks like you’re using BGP between your CE and PE devices. Remember that when using BGP, you can advertise networks in two ways: redistribution and by using the network command. This is detailed in the following lesson:
In your configuration, I see you have used redistribution, and in particular, the redistribution of connected and static routes. This is why your 192.168.201.0/24 is propagated.
However, BGP will not advertise a default route using redistribution. It must be done using the default information-originate command that you correctly realized will solve your problem. The reason it must be implemented in this way is detailed in the following post:
