Dear Lagapides
Thank you for you replied, I have noticed Interface which connect to distribute switch is up/down every time that STP topology changes (And it is up/down only on Core switch interface Only, Distribute has no log interface up/down but found STP topology changes from interface which connect to access switch)
On Core switch shown:
show interface (which up/down state) on Core switch :
Core-Switch#sh int g1/0/14
GigabitEthernet1/0/14 is up, line protocol is down (notconnect) *----> and then line protocol is up*
Hardware is Gigabit Ethernet, address is 4ce1.7555.448e (bia 4ce1.7555.448e)
Description: to ASW-2950-FAC-1-temp
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:21, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d10h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 5461
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 218000 bits/sec, 107 packets/sec
5 minute output rate 460000 bits/sec, 90 packets/sec
15172136 packets input, 4344071086 bytes, 0 no buffer
Received 1334815 broadcasts (416646 multicasts)
0 runts, 0 giants, 0 throttles
39 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 416646 multicast, 0 pause input
0 input packets with dribble condition detected
14838084 packets output, 8364169398 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
Show log on Core switch :
Jul 27 09:03:30.393 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:03:35.176 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:10:17.726 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:10:22.461 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:11:17.178 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:11:21.926 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:13:08.282 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:13:12.971 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:13:46.200 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:13:50.938 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:14:29.097 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:14:33.879 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:16:13.027 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:16:17.769 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 27 09:17:28.441 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to down
Jul 27 09:17:33.139 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
And how spanning tree on Core switch :
Core-Switch#sh spanning-tree vlan 223 de
VLAN0223 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 24576, sysid 223, address 4ce1.7555.4480
Configured hello time 2, max age 20, forward delay 15
We are the root of the spanning tree
Topology change flag not set, detected flag not set
Number of topology changes 1853 last change occurred 00:01:24 ago
from GigabitEthernet1/0/14
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 1, topology change 0, notification 0, aging 300
On Access switch has no log up/down on any interface and found STP topology changes on interface which connect to Distribute switch.
Core switch and Distribute switch : PVST
Config on core switch :
spanning-tree mode pvst
spanning-tree extend system-id
spanning-tree vlan 1-2,203-206,222-223,230-231 priority 24576
Config on distribute switch :
**Access switch : Rapid-pvst**
spanning-tree mode rapid-pvst
