Hello Chris
Yes, that would make sense. In this way, you are also evaluating the state of the S1/0 interface on R4. If either interface on R4 goes down, the SLA will fail, and routing will be rerouted.
Hello Chris
What happens if you have another entry e.g.:
route-map PBR permit 20
ip next-hop x.x.x.x
If the tracked next-hop in entry 10 is down, will it continue through the PBR and use the next-hop for entry 20, or go straight to the routing table?
Sam
I had a think, and would be right in assuming that it wouldnât continue because the match commands were met? And it just doesnât use the next-hop because it is down.
Hello Samir
Yes, you are right. Even if the tracked next-hop fails, the first match statement is fulfilled, so the route map stops searching because it has found a match. So even if you put in your statement 20, traffic to the HTTP server would never be matched by this. But other traffic would be matched, so your permit 20 statement would apply to all traffic except the IP address of the HTTP server. Remember that if you donât have a match statement, then the statement matches everything.
You can find out more details about route maps in general at the following lesson:
Thanks, yes it was very helpful. Am I also right in saying that for route-maps used in PBR, any non-routing set commands - e.g. set ip precedence - are still carried out even if the tracked next hop is down?
Hello Samir
Only the set commands found within a route map that reference a particular tracked object will be affected by the status of that tracked object. So yes, any additional set commands that donât reference the (failed) tracked object will be applied normally.
Yes, thanks for clearing that up.
Hello Rene and Lazaros,
Would tracking an IP other than the nexthop be valid? For example 8.8.8.8 on the Internet?
Hello Ernesto
Yes, that would be valid. In each case, you have to examine the conditions under which the SLA could fail. This is not readily percievable, and has some subtleties that you should keep in mind.
If you track only the next hop, then any downstream failure will not be examined at all in your choice of next hop. Only if the directly connected neighbor fails will the SLA fail, and thus an alternate route is chosen. However, if you track 8.8.8.8, and a downstream router fails, the SLA will fail, and a reroute will take place.
If the purpose of the next hop router is only to reach the Internet, then yes, tracking 8.8.8.8 is fine. But if that router is used to reach other parts of your internal network, then it is best to track the next hop only. Otherwise, if your ISP fails, it will trigger the SLA, and youâll be rerouting internal traffic for no reason. Does that make sense?
