Route not learning on both vEdge device
Lets say we have two edge router.
vEdge1 and vEdge2.
I configured vEdge 1 through template and Evdge 2 via CLI.
Design is VERY much similar, what we are learning here.
Problem - I don’t see route of connected switch’ with vEedge2 in VEdge1 and vice-versa.
vEdge1# show ip route
Codes Proto-sub-type:
  IA -> ospf-intra-area, IE -> ospf-inter-area,
  E1 -> ospf-external1, E2 -> ospf-external2,
  N1 -> ospf-nssa-external1, N2 -> ospf-nssa-external2,
  e -> bgp-external, i -> bgp-internal
Codes Status flags:
  F -> fib, S -> selected, I -> inactive,
  B -> blackhole, R -> recursive
                                            PROTOCOL  NEXTHOP     NEXTHOP          NEXTHOP
VPN    PREFIX              PROTOCOL         SUB TYPE  IF NAME     ADDR             VPN      TLOC IP          COLOR            ENCAP  STATUS
0      10.1.0.0/24         static           -         ge0/0       10.199.199.254   -        -                -                -      F,S
0      10.19.19.0/24       connected        -         ge0/1       -                -        -                -                -      F,S
0      10.199.199.0/24     connected        -         ge0/0       -                -        -                -                -      F,S
0      172.16.1.1/32       connected        -         system      -                -        -                -                -      F,S
10     10.2.0.0/24         connected        -         ge0/2       -                -        -                -                -      F,S
vEdge1# show ipsec outbound-connections
SOURCE                                  SOURCE  DEST                                    DEST                        REMOTE           REMOTE           AUTHENTICATION            NEGOTIATED                     PEER       PEER
IP                                      PORT    IP                                      PORT    SPI     TUNNEL MTU  TLOC ADDRESS     TLOC COLOR       USED           KEY-HASH   ENCRYPTION ALGORITHM  TC SPIs  KEY-HASH   SPI
10.199.199.2                            12386   10.19.19.2                              12406   259     1442        172.16.1.2       biz-internet     AH_SHA1_HMAC   *****14cf  AES-GCM-256           8        NONE       0
vEdge1# show run vpn 10
vpn 10
 interface ge0/2
  ip address 10.2.0.254/24
  no shutdown
 omp
  advertise connected
vEdge2# show ip route
Codes Status flags:
0      10.1.0.0/24         static           -         ge0/0       10.19.19.254     -        -                -                -      F,S
0      10.19.19.0/24       connected        -         ge0/0       -                -        -                -                -      F,S
0      10.199.199.0/24     connected        -         ge0/1       -                -        -                -                -      F,S
0      172.16.1.2/32       connected        -         system      -                -        -                -                -      F,S
10     10.3.0.0/24         connected        -         ge0/2       -                -        -                -                -      F,S
vEdge2# show ipsec outbound-connections
10.19.19.2                              12406   10.199.199.2                            12386   259     1442        172.16.1.1       biz-internet     AH_SHA1_HMAC   *****0c2a  AES-GCM-256           8        NONE       0
vEdge2# show run vpn 10
vpn 10
 interface ge0/2
  ip address 10.3.0.254/24
  no shutdown
vSmart1# show omp peers
R -> routes received
I -> routes installed
S -> routes sent
                         DOMAIN    OVERLAY   SITE
PEER             TYPE    ID        ID        ID        STATE    UPTIME        R/I/S
172.16.1.1       vedge   1         1         2         up       0:13:13:03        1/0/1
172.16.1.2       vedge   1         1         3         up       0:12:35:31        1/0/1
Hello @sumitsinha4u ,
Here’s a step-by-step troubleshooting example:
https://notes.networklessons.com/cisco-sd-wan-verify-connectivity-in-service-vpn
One thing I see is that you don’t advertise service VPN 10 on vEdge2:
vpn 10
 interface ge0/2
  no shutdown
This should be:
vpn 10
 interface ge0/2
  no shutdown
omp
  advertise connected
