Segment routing V6
Dear all,
I’m wondering if you’ll upload some lessons about Segment routing V6.
It will soon replace the MPLS tecnology.
Thanks you very much for all the lessons you’ve published till now
Wish you a great day
Aronne
Hello Aronne
Thank you for your kind words! If you have suggestions for future lessons such as Segment Routing, I would recommend that you go to the Member Ideas page and post your suggestion there:
You may find that others have made similar suggestions and you can add your voice to theirs.
In the meantime, we have some material on Segment Routing in our NetworkLessons notes that you may find useful:
