Source and Destination NAT
Can you explain Source and Destination Nat in ASA and also in IOS with a scenario… Please…
Hi Sushanth,
Source NAT is typically used for Internet access where we translate the source address of a host to the public IP address of our router. Here is an example for Cisco IOS and ASA:
https://networklessons.com/cisco/ccie-enterprise-infrastructurehow-to-configure-pat-on-cisco-ios-router/
Destination NAT is typically used for load balancing. We translate the destination when the packet goes from the outside to the inside. I don’t have a complete lesson for this but here is a quick example for Cisco IOS. Here’s the config of the NAT router:
hostname R1
ip cef
interface GigabitEthernet0/1
 ip address 192.168.12.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/2
 ip nat outside
ip nat pool TELNET_SERVERS 192.168.12.1 192.168.12.2 prefix-length 24 type rotary
ip nat inside destination list PUBLIC_IP pool TELNET_SERVERS
ip access-list standard PUBLIC_IP
 permit 172.16.1.1
We have two telnet servers, 192.168.12.1 and 192.168.12.2. This router can use 172.16.1.1 on the outside, this could be a public IP.
When a device on the outside (192.168.1.1) connects to 172.16.1.1, the first time you get:
R1#
NAT*: s=192.168.1.1, d=172.16.1.1->192.168.12.1 [47462]
And the second time:
R1#
NAT*: s=192.168.1.1, d=172.16.1.1->192.168.12.2 [11370]
So it gets load balanced to 192.168.12.1 first, then to 192.168.12.2.
Hope this is helpful!
