I have a network Core, Distribution, Acess design, from the core we have 4 remote Campues Distribution Switches connected via OSPF.
Sudden Restart from the Remote campus cause one of the distribution switches not to be active for OSPF
Let me make it clear
Before Restart
-OSPF was working from the Dist to the core
After Restart
-With the same or working Configuration of OSPF only one remote Campus not working for OSPF
-the core and the remaining 3 sites working fine with OSPF
-for the Distribution Switch which refuses OSPF, I configure EIGRP redistribute with the Core OSPF service is working now
Distribution Switch Not working info
License Information for ‘WS-X45-SUP8-E’
License Level: entservices Type: Permanent Right-To-Use
Next reboot license Level: entservices
cisco WS-C4507R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS2015Q0NY
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
498 Virtual Ethernet interfaces
192 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Core switch info
cisco WS-C6504-E (R7000) processor (revision 2.0) with 1040384K/8192K bytes of memory.
Processor board ID FOX1501G656
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
6 Gigabit Ethernet interfaces
36 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
working Distrbution info
cisco WS-C4506-E (MPC8548) processor (revision 6) with 1048576K bytes of memory.
Processor board ID FOX1503GNF4
MPC8548 CPU at 1.33GHz, Supervisor 6-E
500 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
