I would like to create traffic policy for prioritizing management traffic (telnet/ssh, snmp) and core data ( actual interest traffic) during congestion. My requirement is that when there is congestion on the backhaul, management traffic has to be prioritized compared to data traffic so that we will have access to remote end device via backhaul. I want to achieve this scenario on destination based IP as my interest traffic pointing to one IP and management access to servers, routers, switched on another IP.
You could start with something like this:
R1(config)#ip access-list extended H1_H2
R1(config)#class-map MGMT_TRAFFIC
R1(config-cmap)#match access-group name H1_H2
R1(config)#policy-map PRIORITY
R1(config-pmap)#class MGMT_TRAFFIC
R1(config-pmap-c)#priority 1000
R1(config-if)#service-policy output PRIORITY
This prioritizes traffic up to 1000 kbps for traffic between 192.168.1.1 and 192.168.2.2 when there is congestion:
R1#show policy-map interface GigabitEthernet 0/1
GigabitEthernet0/1
Service-policy output: PRIORITY
queue stats for all priority classes:
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
Class-map: MGMT_TRAFFIC (match-all)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: access-group name H1_H2
Priority: 1000 kbps, burst bytes 25000, b/w exceed drops: 0
0 packets, 0 bytes
Match: any
Rene, Thanks, could you please let me know whether I should apply this configuration in both peer Router. Also I am using pure IPsec( Tunnel mode), hence I configured QoS pre-classify under crypto map on both peer routers and service policy under WAN interface (where IPsec is getting form), but I could see traffic under only one router where traffic is initiating from LAN and other end router I can’t see the traffic under my class map for FTP but I can see packet increaments in default class. Is there any idea how I can get rid off from this situation.
Dear Rene, Please find my configuration from both back haul router.
SB-RTR00:
class-map match-all FTP
match access-group name MGMT-TRAFFIC
policy-map FTP-PRIORITY
class FTP
bandwidth percent 25
crypto isakmp policy 10
encr aes 256
hash sha512
authentication pre-share
group 2
lifetime 86399
crypto isakmp key XXXXXXX address x.x.x.x
crypto ipsec transform-set YYYYYYY esp-aes esp-sha512-hmac
mode tunnel
crypto map PPPPP local-address GigabitEthernet0/0/0
crypto map PPPPP 10 ipsec-isakmp
set peer X.X.X.X
set transform-set YYYYYYY
match address IPSEC-ACL
qos pre-classify
ip access-list extended MGMT-TRAFFIC
permit tcp host 10.1.1.10 host 11.1.1.10 eq ftp ftp-data
ip access-list extended IPSEC-ACL
permit ip any 11.1.1.0 0.0.0.255
interface GigabitEthernet0/0/0
description ### Connected to Backhaul ###
bandwidth 3000
ip address x.x.x.x 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
no lldp transmit
no lldp receive
no mop enabled
crypto map PPPPP
service-policy output FTP-PRIORITY
SB-RTR01
class FTP
encr aes 256
hash sha512
group 2
lifetime 86399
crypto isakmp key xxxxxx address x.x.x.x
crypto ipsec transform-set yyyyyy esp-aes esp-sha512-hmac
mode tunnel
crypto map QQQQQ local-address GigabitEthernet0/0/0
crypto map QQQQQ 10 ipsec-isakmp
set peer x.x.x.x
set transform-set yyyyyy
qos pre-classify
description ### Connected to backhaul ###
bandwidth 3000
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
no lldp transmit
no lldp receive
no mop enabled
crypto map QQQQQ
permit tcp host 11.1.1.10 host 10.1.1.10 eq ftp ftp-data
permit ip 11.1.1.0 0.0.0.255 any
You might want to check your access-lists:
and
Is 11.1.1.10 your FTP server and 10.1.1.10 your client? If so, the first access-list is correct but the second one isn’t.
If you use passive FTP, you also need to add some extra port numbers.
