Hi guys. I would like to share (and propose, as you can add them to the lesson) some additional debug commands I’ve discovered that can be used to better troubleshoot the scenarios in the lesson.
1. OSPF Network Command
R1#sh ip ospf database
OSPF Router with ID (192.168.12.1) (Process ID 1)
R2#sh ip ospf database
OSPF Router with ID (192.168.12.2) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
192.168.12.2 192.168.12.2 210 0x80000001 0x00DDE6 1
The commands help to figure out that OSPF at R1 doesn’t know any network to “advertise” via LSAs. It’s a good hint to figure out later that there is a typo on the configured network.
2. OSPF Passive Interface
R2#debug ip ospf hello
OSPF hello debugging is on
*Jun 11 16:24:14.426: OSPF-1 HELLO Et0/0: Send hello to 224.0.0.5 area 0 from 192.168.12.2
R1#debug ip ospf packet
OSPF packet debugging is on
*Jun 11 16:24:33.489: OSPF-1 PAK Et0/0: Drop packet, OSPF not running or passive
These debugs show that R2 is sending hellos, but R1 is not accepting them.
Also, taking a look at R2, we see that hello expire counters decreases until eventually timeout:
R2#show ip ospf interface Ethernet 0/0 | include Hello due
Hello due in 00:00:02
3. OSPF Multicast Filtering
R1#debug ip ospf hello
*Jun 11 16:48:28.374: OSPF-1 HELLO Et0/0: Send hello to 224.0.0.5 area 0 from 192.168.12.1
R1#
*Jun 11 16:48:32.202: OSPF-1 HELLO Et0/0: Rcv hello from 192.168.12.2 area 0 192.168.12.2
*Jun 11 16:48:32.202: OSPF-1 HELLO Et0/0: No more immediate hello for nbr 192.168.12.2, which has been sent on this intf 2 times
*Jun 11 16:48:32.202: OSPF-1 HELLO Et0/0: Send hello to 224.0.0.5 area 0 from 192.168.12.2
These commands show that R2 is sending hellos to R1, and R1 is receiving R2 hellos. It also shows that R1 is sending hellos to R2, but R2 doesn’t seem to be replying to them.
4. OSPF Subnet Mask, 5. OSPF Hello & Dead Interval and 6. OSPF Authentication
Nothing to contribute here
7. OSPF Area Mismatch
R1#show ip ospf database
192.168.12.1 192.168.12.1 121 0x80000014 0x00D072 0
192.168.12.2 192.168.12.2 503 0x80000013 0x009D9D 1
Router Link States (Area 1)
192.168.12.1 192.168.12.1 89 0x80000003 0x00E9DA 1
192.168.12.2 192.168.12.2 104 0x80000001 0x00C18B 1
We see the same router IPs (192.168.12.1, 192.168.12.2) advertised as “Router Link States” in both areas (Area 0 and Area 1), which is a good hint for the cause of the issue.
After solving the issue:
192.168.12.1 192.168.12.1 7 0x80000015 0x00A595 1
192.168.12.2 192.168.12.2 8 0x80000017 0x009F96 1
Net Link States (Area 0)
192.168.12.2 192.168.12.2 8 0x80000001 0x00CE8E
Now router IPs “Router Link States” are in Area 0. Note that the whole network will also appear in “Net Link States” also in Area 0.
8. OSPF Area Type Mismatch
Nothing to add
9. OSPF DR/BDR Election
R1#debug ip ospf adj
OSPF adjacency debugging is on
R1#clear ip ospf process
Reset ALL OSPF processes? [no]: yes
*Jun 11 19:46:53.542: OSPF-1 ADJ Et0/0: Interface going Up
*Jun 11 19:47:01.142: OSPF-1 ADJ Et0/0: 2 Way Communication to 192.168.12.2, state 2WAY
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: end of Wait on interface
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: DR/BDR election
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: Elect BDR 0.0.0.0
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: Elect DR 0.0.0.0
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: DR: none
*Jun 11 19:47:04.693: OSPF-1 ADJ Et0/0: BDR: none
The debug shows that no DR/BDR was elected, hence the phases stopped in the 2WAY. It doesn’t help much since it doesn’t explain why (i.e. that both routers have priority zero), but it’s cool to see the debug messages.
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: DR/BDR election
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: Elect BDR 192.168.12.1
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: Elect DR 192.168.12.1
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: Elect BDR 0.0.0.0
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: DR: 192.168.12.1 (Id)
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: BDR: none
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: Nbr 192.168.12.2: Prepare dbase exchange
*Jun 11 19:58:18.862: OSPF-1 ADJ Et0/0: Send DBD to 192.168.12.2 seq 0x5D9 opt 0x52 flag 0x7 len 32
*Jun 11 19:58:21.020: OSPF-1 ADJ Et0/0: Rcv DBD from 192.168.12.2 seq 0x1F0E opt 0x52 flag 0x7 len 32 mtu 1500 state EXSTART
*Jun 11 19:58:21.020: OSPF-1 ADJ Et0/0: NBR Negotiation Done. We are the SLAVE
*Jun 11 19:58:21.021: OSPF-1 ADJ Et0/0: Synchronized with 192.168.12.2, state FULL
Now, the DR/BDR election happened. Note that only R1 proposed itself to be the DR (R2 didn’t, as it continues to have priority=0).
10. OSPF Network Type
There are 2 solutions in the example. In the first one, we explicitly set the neighbors (as the network type for OSPF is NON_BROADCAST).
I think it’s worth to add the neighbor command output:
R1#show ip ospf neighbor
192.168.12.2 0 FULL/DROTHER 00:00:05 192.168.12.2 Ethernet0/0
Note that the state is FULL, but there is no DR/BDR now in this case, which is expected (since it’s not a multi-point/broadcast link).
