Need TWAMP scenario and testing procedure along with tool of SPIRENT or IXIA.
we have lot of testcases regard this testing.
Hello Shakil
For your reference and for that of our other readers, you can find out more about TWAMP at the following NetworkLessons note on the topic.
TWAMP is outside the scope of the topics covered on NetworkLessons. However, I can share with you some high-level information concerning its implementation, and the tools you mention.
To set up a TWAMP scenario and testing procedure, you will need to follow these steps:
Setting up the Test Environment: You need to set up a network environment that includes a sender (client), a receiver (server), and the network conditions you want to test.
Configuring the TWAMP: On the sender and receiver, configure the TWAMP settings. This includes setting the IP addresses, port numbers, and other parameters that will be used in the tests.
Running the Tests: Start the TWAMP sessions and send test traffic from the sender to the receiver. Monitor the network performance metrics such as delay, jitter, and packet loss.
Analyzing the Results: Use the results to analyze the network performance and identify any issues.
As for the tools, both Spirent and Ixia provide solutions for TWAMP testing. You can refer to their respective websites for documentation concerning how to set those up.
Remember, the testing procedure may vary based on the specific requirements of your network and the features supported by the testing tool you are using. It’s recommended to refer to the tool’s documentation for more detailed instructions.
I’m sorry we can’t get into more detail about this, but all the same…
Do you have any idea to add in future..?
Hello @shashakil ,
I don’t have any plans for it at the moment, but you can create an idea here:
If there is enough demand, I will consider it.
