Unable to pin diagrams any lessons
Team, I do not see the option to pin diagrams any more during lessons. I have checked lessons from multiple courses and it seems to be the case with all of them! Why is this so? Any errors? The option to pin diagrams is extremely useful and should be available asap. Please check.
Rahul
Hello Rahul
I find that I am still able to pin the diagrams on the lessons that I am looking at. Can you share with us the browser you are using, including the version number? I also suggest that you try to connect using a different browser or from another PC or laptop to see if you’re still getting the same behavior. Let us know your results so that we can help you resolve the issue.
