I’m try to upgrade from 7.3(0)D1(1) to 8.1(2) via ISSU.
I’m getting the following error:
Return code 0x40930011 (Image verification failed).
I check the file MD5sum and they are equal.
This are the command that I have used:
show file bootflash: filename md5sum
show incompatibility system bootflash:n7000-s2-dk9.8.1.2.bin
show install all impact kickstart bootflash:n7000-s2-kickstart.8.1.2.bin system bootflash:n7000-s2-dk9.8.1.2.bin
install all kickstart bootflash:n7000-s2-kickstart.8.1.2.bin system bootflash:n7000-s2-dk9.8.1.2.bin
Software
BIOS: version 2.12.0
kickstart: version 7.3(0)D1(1)
system: version 7.3(0)D1(1)
BIOS compile time: 05/29/2013
kickstart image file is: bootflash:///n7000-s2-kickstart-npe.7.3.0.D1.1.bin
kickstart compile time: 1/11/2016 16:00:00 [02/11/2016 05:48:57]
system image file is: bootflash:///n7000-s2-dk9-npe.7.3.0.D1.1.bin
system compile time: 1/11/2016 16:00:00 [02/11/2016 08:08:08]
