Useful links for CCIE R&S on the Cisco Doc CD
https://networklessons.com/cisco/ccie-enterprise-infrastructureuseful-links-for-ccie-rs-on-the-cisco-doc-cd/
Unfortunately those ethertype values leave out a lot of important stuff, especially within the CCIEv4 and v5 context. I will repeat a couple here for completeness.
0x800 = IPv4
0x86DD = IPv6
0x8100 = 802.1Q encapsulation (including dot1q-tunneling)
0x806 = IPv4 ARP
0x8863 = PPPoE discovery
0x8864 = PPPoE session
0x8847 = MPLS unicast
0x8848 = MPLS multicast
The Cisco documentation path to the IBM Bridging version of Ethernet Type Codes is:
Products - IOS/NX-OS - IOS - 12.2 Family - 12.2 Mainline - Release 12.2 - Cisco IOS Bridging and IBM Networking Command Reference, Volume 1 of 2, Release 12.2 (under Command References section) - Appendix - Ethernet Type Codes
This has the IPv6 entry of 86DD, but not the 88xx ones mentioned above in Nick Russo’s comment. There is a 15.x version of this too, but it doesn’t even have the IPv6 entry - strange.
And the Regular Expressions page is also available under IOS 15.3, using the same path you mentioned above (minus the Appendixes step).
