Viptela SDWAN templates
hello
I am trying to convert a legacy IOS-XE configuration to SDWAN templates
has anyone used a template for 802.1q trunking ?
Hello Sean
Unfortunately, no I have not had experience with this particular process. However, after doing some research, I have found the following general description that you can follow that may help you out:
In SD-WAN templates, the equivalent of 802.1q trunking is under the VPN Interface Ethernet configuration. Here are the steps:
  • Go to the Device tab.
  • Click on Templates.
  • In the Feature Template section, select VPN Interface Ethernet.
  • Create a new template or modify an existing one.
  • In the template configuration, scroll down to the Sub-interface section.
  • Click on Add New Sub-interface.
  • Enter the VLAN ID under the VLAN field which corresponds to the 802.1q tag.
  • Set the Interface type to Trunk.
  • Remember to apply this template to the appropriate VPNs and devices. Also, don’t forget to push the configuration to the devices.
Please note that this is a basic configuration. Depending on your network design and requirements, you might need to configure additional settings like QoS, ACLs, etc.
If you need any further or more specific information, let us know and we’ll see what we can do to help you further…
