Hello Nicolas
This is a very detailed and intricate design, resulting in some interesting routing behavior in your production environment.
I will go over it at a relatively high level, since we’re a more certification-focused forum. Your diagnosis is correct. This is a well-known, expected behavior in Cisco NX-OS VXLAN EVPN vPC designs.
The core problem is that in a vPC pair, both switches share a common Anycast VTEP IP configured as the secondary IP on the NVE source loopback. Without advertise-pip, both vPC peers advertise their EVPN Type-5 routes using this shared Anycast VTEP IP as the BGP next-hop, even for routes that are unique to a specific switch (like individual loopbacks).
When the Spine/Route-Reflector reflects that Type-5 route back to the other vPC peer, the receiving switch inspects the BGP next-hop and recognizes it as one of its own locally configured addresses (the Anycast secondary IP on its own NVE loopback). NX-OS will not install a route whose BGP next-hop resolves to a locally owned address. It is treated as a self-originated or locally connected route and is silently rejected/not installed in the RIB/FIB.
This happens symmetrically on both peers:
- Peer-1’s loopback Type-5 → advertised with Anycast VTEP as NH → Spine reflects to Peer-2 → Peer-2 sees NH = its own local Anycast IP → route dropped
- Peer-2’s loopback Type-5 → same thing happens → Peer-1 drops it
The Spines are doing their job correctly. The problem is specifically on the receiving vPC peer.
Now the advertise-pip feature was specifically engineered by Cisco to resolve this exact scenario. When enabled on the NVE interface, it forces NX-OS to use each switch’s unique Primary IP (PIP) as the BGP next-hop for locally-originated EVPN routes (Type-2 and Type-5), rather than the shared Anycast VTEP IP. more info can be found here:
There is no clean, fully supported, scalable workaround that avoids advertise-pip for this specific problem. However, if you HAVE to do it without that feature, then one of these three options may be beneficial depending on your constraints:
- Option 1: Keep loopbacks in the Underlay (Recommended if avoiding advertise-pip)
- Option 2: Dedicated L3 Peering Between vPC Peers in the Tenant VRF
- Option 3: Static Routes (Not Recommended)
For this particular problem, advertise-pip is the cleanest and most correct solution unless you intentionally redesign the reachability so those loopbacks are not dependent on EVPN Type-5 routes using the shared anycast next-hop.
