What’s Mean by segment routing and its benefits over tradition routing??
Hello Muhammad
Segment routing is a type of source routing, and in order to understand it, it is important to first understand source routing.
Source routing is a routing methodology that allows the sender to either partially or fully determine the route a packet will take through the network. This is in contrast to traditional routing where routing decisions are made incrementally at each router/node along the path. This allows for easier troubleshooting and allows a host to “know” all of the possible paths to the destination.
Segment routing is a type of source routing that is being developed by the IETF. In a segment routed network, an ingress router may prepend a header to packets that contain a list of segments, which are instructions that are executed on subsequent routers in the network. These instructions may be forwarding instructions, such as an instruction to forward a packet to a specific destination or interface.
Segment routing works on top of IPv6 or MPLS. An excellent description of this mechanism can be found at the following Cisco documentation.
Hi Muhammad,
Segment routing is a source based transport technology that provides simplicity, scalability and 100% protection on main and backup links. It uses segments behind it to work.
There are two types of segments: IGP segments and BGP segments.
Segment routing is also designated by SR and it has some beneffits than traditional IP/MPLS networks, as described bellow:
1 - Scalability
2 - Simplicity
3 - Zero microloops
4 - SDN support
5 - Network Programability for IPv6 (SRV6)
In traditional IP/MPLS networks there is something we call microloop, it happens more on ring topology, MPLS try to solve it with Loop Free Alternate but do not guarantee 100% link protection, SR uses Topology Independent Loop Free Alternate (TI-LFA), that in case of link failure do not wait for IGP convergence… TI-LFA informs about the failure in less than 50 mili second eliminating microloop and giving 100% of link protection in all cases.
Feel free to contact me for more details.
Nilton de Matos
CCIE RnS #61356
+244 921 300 811
