Hi team
what is the dual-active detection concept ?
To achieve dual active detection - do we need to have separate link between both VSS chassis OR it is part of VSL ?
Hi team
Hi Abhishek,
If your VSL fails then the standby switch canât tell if the active switch is still there or not. If the standby switch goes active while the active switch is still there, both will be active, forwarding packets and youâll run into issues. This is called âdual activeâ.
Dual-active detection is configured outside of the VSL link. Thereâs enhanced PAgp, BFD and Dual-Active Fast Hello Packets to use. You can use one or all three at the same time.
Cisco has a pretty good document for this:
19 posts were merged into an existing topic: Cisco 6500 VSS Configuration Example
Is it necessary to use a port channel to configure vss?
I currently only have 2 sfps to connect two
4506-E switches
Hello Helen
The use of two or more links for the Virtual Switch Link (VSL) is only a recommendation by Cisco. It is not manditory. However, this is not recommended as VSS is designed to be a high availability system and by having only one link, this high availability is sacrificed. It should be implemented fully realising this. Ideally, you should purchase an additional module to implemente multiple links.
Iâm sure Iâm missing something here but if I were to use VSS on 2 layer 3 4500 chassis and wanted to connect a access switch to the VSS pair would I use a regular port channel to connect to the VSS pair from the access switch or is there an actual multi-chassis Ethernet port configuration I would need to configure between the access switch and the VSS pair? Iâm just a bit confused as to what configuration I need to connect multiple access layer switches to the VSS pair. Iâve been trying to research it but am pretty confused about the topic as Iâm not able to see a straight forward answer. Any clarification would be helpful.
Hello Jason
There is no special configuration that you need to apply to the access switch that connects via etherchannel to the VSS pair. From the point of view of the access switch, the etherchannel that is being configured would be exactly the same whether both (or all) links are connected to the same physical switch or if they are connected to both members of the VSS pair. The special configuration would be applied on the VSS pair side.
Take a look at the following Cisco documentation that describes such a configuration:
Hey, you mentioned that NSF and SSO donât have to be configured but Cisco documentation says otherwise: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vss.html#wp1130268 âConfigure SSO and NSF on each chassisâ
Do I miss something here, or itâs something new that you arenât familiar with?
Hello Inon
Yes, you are correct that according to Cisco documentation, both SSO and NSF are necessary in order for VSS to function. Rene doesnât mention in the lesson that they donât have to be configured, but mentions them as features and explains what they do. In any case, I will ask Rene to take a look and to make any clarifications necessary to the lesson to avoid confusion.
Thanks for bringing this up!
In the VSS lesson there was a mention that not all ports are compatible for VSL, is there a reason for this? If anyone has an explanation or an article that I can read I would be very grateful.
Hello Justin
VSS requires that VSLs are configured on 10Gbps ports only. Not only this, but these ports must either be on the supervisor itself or on one of several switching modules. You can find more info about this at the following Cisco documentation:
Look at the section titled âVSL Hardware Requirementsâ.
Now the reason that only specific ports can be used is because the requirements of the VSL are very specific. A VSL link has the following characteristics:
All of these restrictions and limitations are there in order to ensure that the link created between the two switches is sufficient to provide the necessary communication for VSS to function.
Ethernet port can be
located on the supervisor engine module or on one of the following switching modules:
⢠WS-X6708-10G-3C or WS-X6708-10G-3CXL
⢠WS-X6716-10G-3C or WS-X6716-10G-3CXL
⢠WS-X6716-10T-3C or WS-X6716-10T-3CXL
In the case that I have to replace a switch on a production stack, should I care to erase the startup-config on the ânew switchâ( that maybe has been used for lab enviroment ) .
Does a switch configuration is a better criteria then uptime of the master? and does the same criteria used for other brands?
Hello Giovanni
If you are talking about replacing one of the switches from a VSS configuration, there is a very specific procedure that must be used which is described in this Cisco documentation:
It is possible to minimize downtime by following this procedure, but itâs a good idea to do it in a maintenance window as there will be some downtime during the replacement process.
Now if youâre talking about replacing a switch from a Stackwise stack, and the new switch is the same model and IOS as the one it is replacing, then the configuration will automatically join the stack and inherit the config of the old switch. But it is always a good idea to first configure the switch number you want before you replace it.
In both cases, itâs a good idea to erase the startup config and start fresh, as this will ensure that no residual configurations can interfere with the configuration that you want.
HI,
Thanks for the reply,
I know that Is a best practice to erase the startup-config but I want to be sure about priority criteria of the stack configuration.
This is what Rene said:
Really a configuration on the SW is a better criteria than the uptime of the master?
In the case that I donât know if the new sw has been erased or not (and Iâm hurry to replace it), do I have to care to check before the configuration?
Can a deprecated configuration on the new SW compromise all my stack?
Hello team,
I have a question. In which cases does packets go through the virtual link?
Hello Giovanni
For argumentâs sake, letâs say you have the following scenario:
A stack of four switches is functioning, and one of those switches fails. You have a switch in storage that happens to be the same model and IOS as the rest of the switches. You donât know what configuration it has, but you add it to the stack. Letâs assume that user priority on all switches is set to the default and is the same.
Hereâs what happens:
So you see, the new switch will never win criterion number 3 (default config) because the already stacked switches will never have a default config. Nor will it win criterion 4 because it has just been powered on.
However, if you shut down the stack, connect the new switch and it doesnât have a default config, and you power them all on again, then criteria 3 and 4 will be tied, so it will ultimately go to criteria 5, the MAC address, which is something that should never happen if you can help it! You should never do this, because stackwise is hot swappable, and it is designed to have switches added while powered on. This will ensure that elections take place correctly.
Having said all of this, it is always best practice, as you know, to manually configure the user priority so that the appropriate switch becomes the master. That way you donât have to worry about evaluating which criterion will win in the election.
Hello Boris
Packets will go through the virtual link only when there is no other way to switch/route them to their required destination. In a VSS arrangement, both chassis perform packet forwarding for ingress traffic on their interfaces, and if possible, ingress traffic is forwarded to an outgoing interface on the same chassis. This is done to minimize data traffic traversing the VSL. If this is not possible, only then will traffic cross the VSL to get to the other chassis to be switched to an egress interface.
In order to minimize or eliminate this, any etherchannels with other devices should be created using a multichassis etherchannel as shown in the diagram below.
Thank you very mauch.
Is there any trick to provide some kind of redundancy at server or devices that connect to the stack with only one cable.
E.g a server or a device that is connected to a patch-panel that ends in a rack with 2 switch in stack.
Hello Giovanni
The standard for providing network connectivity redundancy to servers is to have two or more network cards on the server, and have each network card physically connected to a different physical switch, either within a stack, a VSS arrangement, or simply to two separate switches. This can be done either using link aggregation, such as LACP/Etherchannel or simply by providing different IP addresses on each network card.
If I have understood correctly, you are looking for a way to have a single physical connection on a server somehow connect to two different switches for redundancy, via a physical patch panel/splitter arrangement. I am not familiar of such a possibility, but it would be possible to create such a splitter. However, because splitters are not active components, there is no way for them to âdetectâ a failure of one switch port to automatically switch over to the other. In any case, even if it were achieved, you still donât have the redundancy you need since there is still a single point of failure, which is the network card of the server, the UTP cable itself, and the splitter/patch panel that would implement the redundancy.
The point of redundancy is not to simply connect to two switches, but to provide a backup for all components of connectivity, including the network cards of the servers, as well as the UTP cables that connect to the multiple switches.
