Thanks Rene very useful
Dear René,
Is it to avoid a security issue that we disable DTP ? If someone bring a rogue switch and plug it et voilĂ we negociate a trunk ?
Thks,
Prince
Hi Prince,
That’s correct, this could be dangerous if your interface is configured for “dynamic auto” or “dynamic desirable”.
If you configured the interface in static “access” or “trunk” then negotiatin can’t change it anymore but you are still sending DTP packets which is a bit pointless, better to just disable them.
Thanks for the reply René,
Prince
Watching you switching videos and I like the background of your terminal. Tale me, which terminal program and font are you using. I would like to use such a background.
Hi Jesse,
Which video did you see?
For a long time I used Linux Mint (Mate edition) with the mate-terminal to record these videos. It was the default font, not sure which one that was.
Nowadays I use secureCRT configured to use the same colors as Pycharm’s darcula (I liked their colors):
Here’s a screenshot of what my SecureCRT looks like:
I’m not sure if this is the best for videos but it’s easy on the eyes, even after hours of hardcore Cisco console work ![]()
Very good information.
thank you
your wonderful
You are welcome Hussein.
Can you explain me what does it mean Trunking negotiation is ON does it means that this particular mode is set to send DTP frames . to the my knowledge only Dynamic desirable and ON mode will send out DTP frames and other modes are doesn’t (Dynamic Auto and Access)
Hello Ankit
When we say that DTP negotiation is ON, it means that the port is in a state where, if the proper DTP packets are sent/received, the port may change its trunking functionality. Negotiation is ON in the following states: Dynamic Desirable, Dynamic Auto or Trunk.
DTP negotiation is OFF when a port is in one of the following states: Access or Non-negotiate.
As for the exchanging of DTP frames, take a look at the following NetworkLessons note that explains when DTP messages are sent.
We use Switchport no negotiate only on Trunks ? Or we use it on access ports as well ?
Hello Abdul
When you configure a port to function as a trunk using the switchport mode trunk command, you are hardwiring that port to function as a trunk. However, it will still send out DTP messages to the other side of the link, and if that side of the link is configured to listen and respond to DTP messages (set to dynamic auto or desireable) it will automatically become a trunk.
By using the switchport nonegotiate command, you disable the sending of any DTP messages completely.
Hello Abdul
The switchport nonegotiate command is only applied on trunk ports. DTP is automatically disabled on ports that are manually configured as access ports.
Hi Rene/Laz,
If we are having trunk mode both side but DTP is disabled means trunking is off, is that mean frame received by switch will be normal frame not tagged one then how frames will be processed by switches b/w each other?
Hello Pradyumna
If you disable DTP, this doesn’t mean that trunking is off. This means that trunk negotiation is off. You can still manually configure a port to function as a trunk simply by using the switchport trunk command.
Whether or not a frame on a particular link will have a tag or not depends on the state in which the link finds itself. If DTP is off, then it depends on the configured switchport mode on the egress port. If DTP is on, then it depends on the result of the negotiation.
If we hard coding the interface as a trunk on both side and disable DTP then how interfaces will react as trunk or access and if we are disabling DTP when interfaces are in trunk mode why is this required?
Hello Pradyumna
There are only two ways to disable DTP:
- configure the port for access mode
- use the
switchport nonegotiatecommand
If you configure a port as a trunk, you are not disabling DTP. You are hard coding the port to trunk, but the port will still send out DTP messages to the other end saying “I’m a trunk, please become a trunk too!” This means that if there is a port on the other end where DTP has not been disabled, and where it has not been manually configured, it will automatically become a trunk.
Mean when port the port is hardcoded Trunk as well as DTP disabled, port will always be Trunk port but we have to configure it at both sides.
